Tweak SNR Margin on Cisco SRP527W-U?
lotusmonad
I've got a new Cisco srp527w-u router which is working fine though it's syncing at a lower rate than my Billion (6mbps vs. 8.5 mbps for the billion on the same line).
I had tweaked the billion way back to connect with a 4db SNR margin and almost certainly this is why it achieves the higher rate (by comparison the cisco is syncing with an snr margin of 12db). Is there some way that I can configure it to use a lower SNR margin? I realize this might reduce connection stability but I'd at least like to be able to give it a try if possible.
Thanks for any help!
Andrew Hickman
Hi Louis,
This level of configuration is not possible with the SRP500.
Andy
Andrew Hickman
Hi Louis,
Andy
Ah pity. Thanks Andrew.
