12-19-2014 09:42 AM
hi, guys thanks for time and help i need a guide for configure this crap of routers
SITE A Static WAN IP X.X.X.X to 10.0.0.7 ipsec/vpn ports
SITE B Dinamyc IP Address DynDNS
1 - First the Remote branch office RV042 when i enable the DynDNS services is updating the host whit the internal ip of the router
example 10.0.0.13
2 - Second the vpn only work when is set the ip addres of the remote office in the main office and not whit the domain name i get this error:
Aggressive mode Enable:
Authorize Fail] no connection has been authorized with policy=PSK+AGGRESSIVE
Aggressive mode Disable:
Jan 1 05:41:41 2010 | VPN Log | (g2gips0)[4] 186.6.29.68:2231: [Tunnel Disconnected] instance with peer 186.6.29.68 {isakmp=#0/ipsec=#0} |
Jan 1 05:41:41 2010 | VPN Log | packet from 186.6.29.68:2231: [Tunnel Authorize Fail] 'g2gips0' forbids connection, cause: Aggressive Mode |
Configuration both sites
SITE A:
WAN1
Local Group Setup:
IP ONLY
IP ADDRESS: 10.0.0.7(NAT)
Subnet
192.168.0.0
255.255.255.0
Remote Group Setup:
DYNAMIC IP + DOMAIN NAME FDQN AUTH
mysite.dyndns.org
Subnet
192.168.1.0
255.255.255.0
Aggressive Mode (Checked, unable to disable or enable)
Keep-Alive Enable
Netbios Broadcast Enable
NAT-Traversal Enable
Deep Inspection Enable
SITE B:
WAN1
Local Group Setup:
IP ONLY
IP ADDRESS: 10.0.0.13(NAT)
Subnet
192.168.1.0
255.255.255.0
Remote Group Setup:
IP: 196.3.81.44
mysite.dyndns.org
Subnet
192.168.0.0
255.255.255.0
Aggressive Mode (i can enable or disable)
Keep-Alive Enable
Netbio Broadcast Enable
12-20-2014 11:01 AM
it seems that in this place the staff respond when he feels like if a person enters a community and posts a question is because you need assistance
where is the staff or technical support?
buy 15 of these routers to 15 remote offices to vpn but I see that it is very difficult with these teams had I dreamed that these routers are so bad and with so little information and support have bought juniper
12-22-2014 09:35 AM
Hi Arnaldo,
For immediate help, please contact the Cisco Small Business Support Center. The contact information is located here: https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy
12-22-2014 11:19 AM
Thanks Cindy for your time and help!!!!
to late in the weekend i change all RV042 for Juniper al vpn are up and working!
thanks take care!
