Unable to do failover with dual isp in rv 340 router
I have a Cisco router RV 340 and have configured both the Wan port with ISP settings
one ISP is using PPOE connection with static ip address provided and other is a fiber connection which is kept on bridge mode on the isp router and provided a Static ip address to the second wan port
now once the wan 1  port goes down which is kept on fail over its not picking up the wan 2 internet
balaji.bandi
Thanks for the reply
both the ISP line is working fine but still when one ISP is down it does not switch to wan 2
how are you failing over or testing, post the config information to confirm what is wrong ?
how are you tracking link down  ? make sure each one track different IP address ?
BB
