VLAN Membership Error
Bobby01101
I'm trying to exclude a port from the default vlan but I receive this error;
A VLAN port can only be untagged to one VLAN ID. (LAN2)
I only have 1 vlan, so I don't see why I should be seeing this?
I'm trying to exclude the port so I can add the port to a new vlan which I haven't created yet. I've tried creating the vlan before hand but I get the same error.
Michael Vandergrift
Hello Bobby,
You need to create all your VLANs first.  Then, once they show up in the VLAN table, check the boxes next to each VLAN and click 'edit'.  Now change the port to 'untagged' or 'excluded' for the desired VLAN.  Remember, only one VLAN can be untagged on each port and there must be an untagged/native VLAN on each port.
Mike.V
Cheers Mike, I had tried adding all the vlans before but I didn't realise you could multi select each vlan, I was trying to do one at a time!
Thanks.
