VPN problem with RV042G
ipenuelas
hello,
I have an static ip in my office and i want to create a vpn tunel but in QuickVPN i am getting --> Failed to Ping remote VPN Router
I have also a dynamic ip and  i have the same error can some one help me?
Router: RV042G
WAN
IP Address: 192.168.0.17
GateWay: 198.168.0.1
Lan settings: 192.168.50.1
Mehdi Boukraa
Hi Ivan,
From the information on RV042G I suppose you have another router front of RV042G because you have a private IP address on the WAN of RV042G , to have Qvpn working just redirect the following port for IPsec 500,4500 UDP and 443 TCP to 192.168.0.17 (WAN IP address of RV042G )
and from the client it self on address server put the public IP address
Some other information related to Windows :
If the client trying to access from Windows 7 or 8 or Vista you need to have firewall enable
If the client trying to access from Windows XP you need to have the firewall disable
Mehdi
*Please rate the Post so other will know when an answer has been found.
Thanks a lot for the answer, now i can connect to mi VPN from my home, but only one client its allow to connect at the same time, i have already added two more vpn clients in the router but it doest let me connect.
I have 2 computers in my home and two users for the VPN
Computer 1 and 2 : Windows 7 Home Basic 64 bits SP1
