08-05-2018 11:21 AM - edited 08-05-2018 01:11 PM
Hi guys,
while i am useing two wan connections and two internet connections (four separate connections ).
Q 1 how i should configure wan redundancy with hsrp.
Q 2 should i use hsrp for internet redundancy also.
rammon.
08-06-2018 03:32 PM
Hello rammon,
Thank you for contacting cisco support community.
Can you please indicate us which is the device model you are trying to use to configure HSRP?
Our small business routers don’t support HSRP.
Thanks in advanced.
Log in to Community
