we need to purchase new cisco router for dual isp failover pls assist the same.
r_jadhav1
LJ Gabrillo
Level 5
Level 5
Cool, considering you have two routers you can configure HSRP between them on the LAN side. Lastly, configure QoS tracking on the default routes on each router. QoS tracking automatically shutsdown the default route in a router if a condition is not in place e.g., cannot ping gateway to internet
Technically R1 and R2 have the mirrored configuration, the only difference is the IP
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
So you have a router now, and you plan to add another?  I.e. you're looking to purchase just one?
Or, you're planning to host both ISP links on the new router?
What's the bandwidth of the ISP link or links to be connected to the new router?
If you have an existing router, what model is it and its IOS version?
we have two isp with 2Mbps both we need to terminate both on single router we need internet failover between them.
so kindly suggest the new router support for internet failover with two isp
Disclaimer
Posting
Oops, sorry for the delayed response.  Lost track of your response.
For 2 Mbps, almost any modern router will easily handle that, such as 800 series, but since you need two ISP links, an 800 might not be choice as you need two ISP interfaces if they are not Ethernet.  If your two ISP interfaces will be Ethernet, an 891 might be suitable choice.  If you need dual serial interfaces, a 1900 series might be suitable such as the 1905 (if its EHWIC will accept something like the HWIC-2T).
