What is definition of forwarding rate and throughput in router ?
keithcktang
Do you have the definition of forwarding rate and throughput
mpyhala
Level 7
Level 7
Hello Chi keung,
I found the following information after a search:
http://tools.ietf.org/html/rfc2285#section-3.6.1
"3.6.1
Forwarding rate (FR)
   Definition:
      The number of frames per second that a device can be observed to
      successfully transmit to the correct destination interface in
      response to a specified offered load."
http://tools.ietf.org/html/rfc1242#section-3.17
"3.17
Throughput
    Definition:
                The maximum rate at which none of the offered frames
                are dropped by the device."
Follow the links for further details.
