09-05-2013 11:00 PM
We have on the Power Supply Rating 3000 W but in actual there is only 2771.16 W available. Can you kindly clarify this abnormality (Initial Rated Power to the Available Actual Supply) with the vendor.
SUPPORT25#sh power
system power redundancy mode = redundant
system power total = 2771.16 Watts (65.98 Amps @ 42V)
system power used = 2128.98 Watts (50.69 Amps @ 42V)
system power available = 642.18 Watts (15.29 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 2771.16 65.98 OK OK on
2 WS-CAC-3000W 2771.16 65.98 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 FAN-MOD-09 241.50 5.75 OK
2 FAN-MOD-09 241.50 5.75 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
2 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
4 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
5 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
6 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
7 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
8 WS-X6582-2PA 105.00 2.50 105.00 2.50 on on
09-06-2013 10:31 AM
Hello Shushil,
It's always like that. You will never have a 100% efficient system in real world, where there is no heat dissipation. So the power that you think is missing is actually going out as heat.
Thank you
Sreenivas
