I have a strange problem where i have 2 sites connected using a VPN on 2 CISCO877. But WMI scripts are not running across the link. if i pull these out an replace them with a Draytek, the scripts run fine.
Broad Lane LAN ----- Cisco 877 ========= Internet & VPN Tunnel ============== Cisco 877 ---- Southam LAN1.0.39.0/8 1.0.39.253 192.168.55.1 192.168.55.0/24 The server at Broad Lane is GIMILI (1.0.39.109) and at Southam is FRODO (192.168.55.4). The following will not work through the tunnel from Broad Lane LAN. Set objWMIService = GetObject("winmgmts:\\192.168.55.4\root\cimv2") if err.number=0 then serverexist=true else serverexist=falsemsgbox(server.exist)
Is is possible for the CISCO877 to block WMI traffic?
Any suggestions please?
Rgds
Phil
