Greetings,
I have a Linksys/Cisco WRV210 Wireless-G VPN Router with RangeBooster. ISP provides dynamic IP with all ports open. I have no equipment to interact with from them; they just provide me a CAT5 cable out of the wall. ISP -> WRV210 -> LAN
Router Stats
Hardware Version: WRTR-221G_V1
Software Version: 2.0.0.11
Connection Type: Automatic Configuration - DHCP
IP Address: 10.1.222.104
Subnet Mask: 255.255.255.0
Default Gateway: 10.1.222.1
Port Forwarding 22152- 22152 192.168.1.152 Enabled
Port Triggering none
DMZ disabled
If I test within the LAN
nmap -p22152 192.168.1.152
Interesting ports on 192.168.1.152:
PORT STATE SERVICE
22152/tcp open unknown
If I test from outside the router (xxx and ### are just my masking edits)
nmap -p22152 desktop.dns.xxx
Interesting ports on ##.###.##.###:
PORT STATE SERVICE
22152/tcp closed unknown
If I test from inside the LAN directed at the router
Interesting ports on 192.168.1.1:
PORT STATE SERVICE
It would seem the router is completely ignoring my Port Forwarding instructions. I have hard reset the router. I have upgraded to the lastest firmware. None of these has made a difference.
My last test was to see if any ports are open on the router
nmap 192.168.1.1
Not shown: 997 closed ports
PORT STATE SERVICE
80/tcp open http
443/tcp open https
60443/tcp open unknown
My questikon would be if anyone has a "trick" to activate port forwarding on the route?
Thank you.
