WRV210 Self reboots
j.greenwell
I've began having problems with the WRV210 where the router just reboots.  Sometimes it may go for an hour or more then it slips into a series of reboots.  The up time varies so I see no pattern.  Contacted support they thought the device may have been defective so we did a RMA.  Well guess what?  The replacement arrived on Friday we put it in place and the same thing is happening.  We are not using any of the VPN or VL options.  Just simple PAT to a few internal machines for RDP access and an internal exchange server.  The Qos is all disabled.  It has the newest firmware which I have reflashed.  I'm at a loss to explain the behavior but it doesn't appear to be isolated to a defective device.  Any ideas would be helpful.
13 Replies 13
daviddun
Level 3
Level 3
Joe,
Just a few questions
Have you looked to see if you are getting any power surges (AKA) power spikes or brown outs? Is the UPS you are using causing the same problems to other devices?
If the router is unplugged from the network, does it do the same thing, and what devices are hanging off the router that could cause the problem.
Just a few quick thoughts
jasbryan
Level 6
Level 6
Joe,
I would try moving where the WRV210 is plugged in to a different circuit, if you don't have a UPS. I would recommend having this unit put on a UPS since you are having instable power surges. If this is a power issue this will certainly fix your issue. Also you might want to look at all the Ethernet cables that are plugged into WRV210 to verify there are no breaks or Kinks.
Jasbryan
Cisco Support Engineer
Here is what I've currently done.  The device was already on a APC UPS.  I've put the previous router in place so that it is working as the gateway.  I've assigned a free IP address to the WRV210 internal interface and connected it to the other gateway.  There is nothing plugged into the WAN port on the WRV210.  That way I can monitor the device and see if it continues the behavior with only a connection on the lan side of the device.
When it was in production there were only two devices connected.  On the WAN side was a SMC cable modem from comcast.  On the lan side was a 24 port netgear router.  When I checked this morning it had been up for 18 hours but that is not unusual.  I will be interested to see what happens the rest of the week.  I can not imagine why the device is doing rebooting.  If it does it again I'm going to switch it to a different ups to verify that is not an issue.
The currently router is a netgear with the same settings as the WRV210 and it has no problems.
     Joe,
Any updates on the WRV210 Rebooting ?
Jasbryan
My WRV210 does the same thing.
I've been trying to figure out why randomly reboots.    Sometimes its hourly, sometimes several hours apart.
But when I check this page:  http://192.168.1.1/StatusRouterDHCP.asp  the System Uptime is never very long.
Or when I'm having an outage or problem, I'll immediately check the status and it says:  System Up time: 30-40 seconds.
So it was clearly a router issue.
Funny thing is I never had this problem when I was on the Linksys 1.x (black & blue) firmware.
Its only been since I "upgrade" to the new Cisco 2.x firmware.
Now I'm trying to find an old firmware to change to.
Chris,
When you upgraded to latest firmware, did you factory reset and reconfigure manually?
Some times new code over old code causes problems if a reset wasn't done.
Jason
I will attempt that later when I have access to the router.
I updated from 2.0.0.11 to 2.0.1.5  yesterday afternoon and did a factory reset, and I'm still having random "reboots".
I assume it is a reboot / restart of some sort as the router goes non-responsive (no internet connections / can not be reach via HTTP interface either) for less than a minute, and the uptime counter resets.
Also, the other problem which I've had with this router is I can not use the QuickVPN client with Windows7 64-bit, it works fine on my older WinXP pc's.
I have an RSV4000 at work and the WRV210 at home, which I sometimes enable the IPsec VPN on, lately I've left it disabled as I thought that was the cause of this connection problem.   However, I realize now the problems were when I "upgraded" from the old Linksys firmwares to the Cisco firmware.
Chris,
Can you try capturing some logs , if i am correct you have to send the logs to a syslog server. This should tell us what happens on the system or around the time the router locking up. Please make a note of the time when the router locks up so we can attempt to reference in the logs. I know qvpn didn't use to work with 64 bit O.S but now only a few customers are having problems. Generally its a problem with PC since Qvpn is just an application that allows you to easily configured the IPsec client that's install in windows to connect to our router. This is why it's free ! If you would like hands on support you can give us a call @ 1866-606-1866 but please have system logs captures before calling in .
You should be able to use any syslog server application, there generally free on the WEB. I like TFTPD32 program because it's can be use as TFTP,SNTP,syslog,DHCP,DNS. NOTE: If you use this program please make sure you disable the DHCP option that comes enabled by default. This can cause problems on the network.
Jason
Well, I've been trying to capture what is causing the router to lock up.   Currently it is happening less since I've updated to 2.0.1.5.  However, the router is still locking up at least once a day.   Unfortunately it always seems to happen when my PC is in power save mode, thus Tftpd32.exe doesn't catch the incident.
Just now, the router was working however the wifi was not, I had to manually unplug the router to get it back working, as trying to enable/disable it via the web interface didn't seem to help.
I do see that I'm having a lot of DoS attacks.   Do you think that could be causing the problem(s) ?
Router just locked up / restarted 4 minutes ago, noticed it went down.
Here's the status so you can figure out what time it restarted:
Hardware Version:WRV210-A V01
Software Version:2.0.1.5
Current Time:2011/08/09 Tue 04:18:36 (GMT -06:00)
System Up Time:4m:57s
And here's the syslog:
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 20:36:51.771
<150>[DoS] [Detected IP Spoofing Attack] (TCP) Outgoing Source:173.131.243.138:39127 Destination:74.125.65.188:5228 [Droped]
192.168.2.1 08/08 20:45:50.299
<150>[DoS] [Detected ICMP Smurf Attack] (ICMP Type:8) Incomming Source:172.19.49.14 Destination:70.171.125.230(37014)[Droped]
192.168.2.1 08/08 20:45:55.915
192.168.2.1 08/08 20:45:55.931
192.168.2.1 08/08 20:47:27.896
<129>syslogd started: BusyBox v1.01 (2011.02.09-16:06+0000) 192.168.2.1 08/08 22:14:13.372
<129>klogd: klogd started: BusyBox v1.00-pre2 (2008.02.27-15:42+0000) 192.168.2.1 08/08 22:14:13.606
<129>klogd: SDRAM size: 32MB 192.168.2.1 08/08 22:14:13.621
<129>klogd: CPU revision is: 0000ff00 192.168.2.1 08/08 22:14:13.652
<129>klogd: Init MMU (16 entries) 192.168.2.1 08/08 22:14:13.652
<129>klogd: Primary instruction cache 0kB, linesize 0 bytes. 192.168.2.1 08/08 22:14:13.652
<129>klogd: Primary data cache 0kB, linesize 0 bytes. 192.168.2.1 08/08 22:14:13.652
<129>klogd: Linux version 2.4.26-uc0 (
root@localhost.localdomain
) (gcc version 3.3.5) #423 Thu Feb 10 00:07:11 CST 2011 192.168.2.1 08/08 22:14:13.668
<129>klogd: Determined physical RAM map: 192.168.2.1 08/08 22:14:13.668
<129>klogd:  memory: 02000000 @ 00000000 (usable) 192.168.2.1 08/08 22:14:13.668
<129>klogd: NOFS reserved @ 0x8040b380 192.168.2.1 08/08 22:14:13.668
<129>klogd: On node 0 totalpages: 8192 192.168.2.1 08/08 22:14:13.684
<129>klogd: zone(0): 8192 pages. 192.168.2.1 08/08 22:14:13.684
<129>klogd: zone(1): 0 pages. 192.168.2.1 08/08 22:14:13.684
<129>klogd: zone(2): 0 pages. 192.168.2.1 08/08 22:14:13.699
<129>klogd: Kernel command line: root=/dev/mtdblock2 noinitrd 192.168.2.1 08/08 22:14:13.699
<129>klogd: IRR(0)=c0000000 192.168.2.1 08/08 22:14:13.699
<129>klogd: Calibrating delay loop... 199.06 BogoMIPS 192.168.2.1 08/08 22:14:13.730
<129>klogd: Memory: 28264k/32768k available (3056k kernel code, 4504k reserved, 124k data, 100k init, 0k highmem) 192.168.2.1 08/08 22:14:13.762
<129>klogd: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes) 192.168.2.1 08/08 22:14:13.777
<129>klogd: Inode cache hash table entries: 2048 (order: 2, 16384 bytes) 192.168.2.1 08/08 22:14:13.777
<129>klogd: Mount cache hash table entries: 512 (order: 0, 4096 bytes) 192.168.2.1 08/08 22:14:13.840
<129>klogd: Buffer cache hash table entries: 1024 (order: 0, 4096 bytes) 192.168.2.1 08/08 22:14:13.886
<129>klogd: Page-cache hash table entries: 8192 (order: 3, 32768 bytes) 192.168.2.1 08/08 22:14:13.886
<129>klogd: Checking for 'wait' instruction...  unavailable. 192.168.2.1 08/08 22:14:13.886
<129>klogd: POSIX conformance testing by UNIFIX 192.168.2.1 08/08 22:14:13.902
<129>klogd: NEW PCI Driver...isLinuxCompliantEndianMode=False(Big Endian) 192.168.2.1 08/08 22:14:13.933
<129>klogd: [PCI] Reset Bridge ..... Finish! 192.168.2.1 08/08 22:14:13.949
<129>klogd: Find Total 8 PCI functions 192.168.2.1 08/08 22:14:13.964
<129>klogd: Found 00:08 [1814/0401] 000280 00 192.168.2.1 08/08 22:14:13.964
<129>klogd: Linux NET4.0 for Linux 2.4 192.168.2.1 08/08 22:14:13.980
<129>klogd: Based upon Swansea University Computer Society NET3.039 192.168.2.1 08/08 22:14:13.980
<129>klogd: Initializing RT netlink socket 192.168.2.1 08/08 22:14:13.980
<129>klogd: Starting kswapd 192.168.2.1 08/08 22:14:13.980
<129>klogd: devfs: v1.12c (20020818) Richard Gooch (
rgooch@atnf.csiro.au
) 192.168.2.1 08/08 22:14:13.996
<129>klogd: devfs: boot_options: 0x1 192.168.2.1 08/08 22:14:13.996
<129>klogd: Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher 192.168.2.1 08/08 22:14:13.996
<129>klogd: pty: 256 Unix98 ptys configured 192.168.2.1 08/08 22:14:13.996
<129>klogd: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SERIAL_PCI enabled 192.168.2.1 08/08 22:14:14.042
<129>klogd: Probing RTL8651 home gateway controller... 192.168.2.1 08/08 22:14:14.042
<129>klogd: Initialize RTL865x ASIC and driver 192.168.2.1 08/08 22:14:14.042
<129>klogd: chip name: 8651B, chip revid: 1 192.168.2.1 08/08 22:14:14.042
<129>klogd:    Initialize mbuf... 192.168.2.1 08/08 22:14:14.058
<129>klogd:    creating default 2 interfaces...eth0 IRR(6)=c0040000 192.168.2.1 08/08 22:14:14.058
<129>klogd: ===> Request IRQ 6 for eth0, ret=0 192.168.2.1 08/08 22:14:14.058
<129>klogd: eth1 ...OK 192.168.2.1 08/08 22:14:14.058
<129>klogd:    creating port0~port9 for 802.1d/1s/1w...0 1 2 3 4 5 6 7 8 ..OK! 192.168.2.1 08/08 22:14:14.136
<129>klogd: Hardware watchdog enabled 192.168.2.1 08/08 22:14:14.136
<129>klogd: PPP generic driver version 2.4.2 192.168.2.1 08/08 22:14:14.136
<129>klogd: PPP Deflate Compression module registered 192.168.2.1 08/08 22:14:14.261
<129>klogd: PPP BSD Compression module registered 192.168.2.1 08/08 22:14:14.261
<129>klogd: MPPE/MPPC encryption/compression module registered 192.168.2.1 08/08 22:14:14.261
<129>klogd: flash device: 800000 at be000000 192.168.2.1 08/08 22:14:14.261
<129>klogd:  Amd/Fujitsu Extended Query Table v1.1 at 0x0040 192.168.2.1 08/08 22:14:14.370
<129>klogd: number of CFI chips: 1 192.168.2.1 08/08 22:14:14.370
<129>klogd: cfi_cmdset_0002: Disabling fast programming due to code brokenness. 192.168.2.1 08/08 22:14:14.370
<129>klogd: Creating 5 MTD partitions on "Physically mapped flash": 192.168.2.1 08/08 22:14:14.401
<129>klogd: 0x00000000-0x00020000 : "boot" 192.168.2.1 08/08 22:14:14.401
<129>klogd: 0x00020000-0x007e0000 : "linux" 192.168.2.1 08/08 22:14:14.401
<129>klogd: 0x001512c0-0x007e0000 : "romfs" 192.168.2.1 08/08 22:14:14.417
<129>klogd: mtd: partition "romfs" doesn't start on an erase block boundary -- force read-only 192.168.2.1 08/08 22:14:14.417
<129>klogd: 0x007e0000-0x007f0000 : "bdinfo" 192.168.2.1 08/08 22:14:14.464
<129>klogd: 0x007f0000-0x00800000 : "cfg" 192.168.2.1 08/08 22:14:14.464
<129>klogd: Initializing Cryptographic API 192.168.2.1 08/08 22:14:14.464
<129>klogd: NET4: Linux TCP/IP 1.0 for NET4.0 192.168.2.1 08/08 22:14:14.464
<129>klogd: IP Protocols: ICMP, UDP, TCP, IGMP 192.168.2.1 08/08 22:14:14.479
<129>klogd: IP: routing cache hash table of 512 buckets, 4Kbytes 192.168.2.1 08/08 22:14:14.479
<129>klogd: TCP: Hash tables configured (established 2048 bind 4096) 192.168.2.1 08/08 22:14:14.479
<129>klogd: GRE over IPv4 tunneling driver 192.168.2.1 08/08 22:14:14.479
<129>klogd: klips_info:ipsec_init: KLIPS startup, Openswan KLIPS IPsec stack version: 2.4.5dr3 192.168.2.1 08/08 22:14:14.479
<129>klogd: klips_info:ipsec_alg_init: KLIPS alg v=0.8.1-0 (EALG_MAX=255, AALG_MAX=251) 192.168.2.1 08/08 22:14:14.526
<129>klogd: klips_info:ipsec_alg_init: calling ipsec_alg_static_init() 192.168.2.1 08/08 22:14:14.526
<129>klogd: ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0 192.168.2.1 08/08 22:14:14.526
<129>klogd: ipsec_aes_init(alg_type=14 alg_id=9 name=aes_mac): ret=0 192.168.2.1 08/08 22:14:14.557
<129>klogd: ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0 192.168.2.1 08/08 22:14:14.557
<129>klogd: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack 192.168.2.1 08/08 22:14:14.573
<129>klogd: ip_conntrack_pptp version $Revision: 1.1 $ loaded 192.168.2.1 08/08 22:14:14.604
<129>klogd: ip_nat_pptp version $Revision: 1.1 $ loaded 192.168.2.1 08/08 22:14:14.620
<129>klogd: ip_tables: (C) 2000-2002 Netfilter core team 192.168.2.1 08/08 22:14:14.620
<129>klogd: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. 192.168.2.1 08/08 22:14:14.666
<129>klogd: NET4: Ethernet Bridge 008 for NET4.0 192.168.2.1 08/08 22:14:14.666
<129>klogd: Bridge firewalling registered 192.168.2.1 08/08 22:14:14.666
<129>klogd: VFS: Mounted root (squashfs filesystem) readonly. 192.168.2.1 08/08 22:14:14.666
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:14:14.682
<129>klogd: Mounted devfs on /dev 192.168.2.1 08/08 22:14:14.682
<129>klogd: Freeing unused kernel memory: 100k freed 192.168.2.1 08/08 22:14:14.682
<129>klogd: IRR(4)=c0c40000 192.168.2.1 08/08 22:14:14.682
<129>klogd: ===> Request IRQ 4 for serial, ret=0 192.168.2.1 08/08 22:14:14.682
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:14:14.698
<129>klogd: rtl8651_user_pid set to 18 192.168.2.1 08/08 22:14:14.698
<129>klogd: Bring up ext  port 6.. 192.168.2.1 08/08 22:14:14.729
<129>klogd: Rx shift=10002 192.168.2.1 08/08 22:14:14.729
<129>klogd:  192.168.2.1 08/08 22:14:14.729
<129>klogd: Set IGMP Default Upstream interface (eth0) ... SUCCESS!! 192.168.2.1 08/08 22:14:14.776
<129>klogd: PPPoE Passthru disabled. 192.168.2.1 08/08 22:14:14.776
<129>klogd: Drop Unknown PPPoE PADT disabled. 192.168.2.1 08/08 22:14:14.776
<129>klogd: IPv6 Passthru disabled. 192.168.2.1 08/08 22:14:14.807
<129>klogd: IPX Passthru disabled. 192.168.2.1 08/08 22:14:14.807
<129>klogd: NETBIOS Passthru disabled. 192.168.2.1 08/08 22:14:14.822
<129>klogd: RTL865x Port 1 state=BLOCKING 192.168.2.1 08/08 22:14:14.822
<129>klogd: RTL865x Port 1 state=DISABLED 192.168.2.1 08/08 22:14:14.822
<129>klogd: device eth1 entered promiscuous mode 192.168.2.1 08/08 22:14:14.822
<129>klogd: RTL865x Port 1 state=BLOCKING 192.168.2.1 08/08 22:14:14.838
<129>klogd: br0: port 1(eth1) entering learning state 192.168.2.1 08/08 22:14:14.838
<129>klogd: RTL865x Port 1 state=LEARNING 192.168.2.1 08/08 22:14:14.838
<129>klogd: RTL865x VLAN STP disabled 192.168.2.1 08/08 22:14:14.838
<129>klogd: pcibios_enable_resources: already enabled when device probed. 192.168.2.1 08/08 22:14:14.838
<129>klogd: pci_request_regions: PCI regions already reserved 192.168.2.1 08/08 22:14:14.838
<129>klogd: pcibios_set_master: already done when device probed. 192.168.2.1 08/08 22:14:14.885
<129>klogd: IRR(5)=c0c40000 192.168.2.1 08/08 22:14:14.885
<129>klogd: ===> Request IRQ 5 for ra0, ret=0 192.168.2.1 08/08 22:14:14.885
<129>klogd: RT2661 Driver version - 1.1.0.0 192.168.2.1 08/08 22:14:14.885
<129>klogd: => Register External Device (ra0) vid (9) extPortNum (6) -- Dev (0x8119b200) 192.168.2.1 08/08 22:14:14.885
<129>klogd: register external ra0 device on extPort 6, id  1 192.168.2.1 08/08 22:14:14.932
<129>klogd: ra0 -- (rtl865x_extDev_registerUcastTxDev [660]) Register Unicast Tx Device [8119b200]. 192.168.2.1 08/08 22:14:14.932
<129>klogd: (rtl865x_extDev_regCallBack [845]) Register CallBack function -- Ucast Tx (c006177c) Free (c0061a10). 192.168.2.1 08/08 22:14:14.932
<129>klogd: src(0xc0a80201),broadip(0xc0a801ff) 192.168.2.1 08/08 22:14:14.963
<129>klogd: src(0x0),broadip(0xff) 192.168.2.1 08/08 22:14:14.963
<129>klogd: br0: port 1(eth1) entering forwarding state 192.168.2.1 08/08 22:14:14.994
<129>klogd: RTL865x Port 1 state=FWD 192.168.2.1 08/08 22:14:14.994
<129>klogd: br0: topology change detected, propagating 192.168.2.1 08/08 22:14:14.994
<129>klogd: @ = Add Host : [bc:47:60:fe:d1:76] VID 9 LinkID 1 PortNumber 6 192.168.2.1 08/08 22:14:14.994
<129>klogd:  192.168.2.1 08/08 22:14:14.994
<129>klogd: rtl8651_user_pid set to 409 192.168.2.1 08/08 22:14:21.499
<129>klogd: rtl8651_user_pid set to 469 192.168.2.1 08/08 22:14:26.351
<129>ipsec__plutorun: 104 "TunnelA" #1: STATE_MAIN_I1: initiate 192.168.2.1 08/08 22:14:28.160
<129>ipsec__plutorun: ...could not start conn "TunnelA" 192.168.2.1 08/08 22:14:28.176
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:15:23.494
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:15:23.525
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:15:23.572
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 08/08 22:15:24.180
Current Time:2011/08/12 Fri 06:19:31 (GMT -06:00)
System Up Time:2m:38s
MAC Address:00:23:69:08:8D:75
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:35:24.059
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:37:25.070
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:40:27.085
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:43:28.114
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:44:28.339
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:44:28.342
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:46:29.354
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:46:29.356
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:48:29.366
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:48:29.367
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:20.381
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:20.383
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:22.402
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:22.404
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:25.421
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:49:25.423
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:50:31.438
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:50:31.440
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:52:31.453
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:52:31.455
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:54:24.468
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:54:24.470
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:55:34.485
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:55:34.486
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:56:38.502
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:56:38.504
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:58:35.519
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:58:35.521
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:59:35.534
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 22:59:35.535
<129>klogd: rtl8651_user_pid set to 630 192.168.2.1 11/08 23:00:04.997
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:01:37.009
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:01:37.011
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:03:37.015
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:05:39.068
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:07:40.082
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:07:40.084
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:09:41.107
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:11:43.145
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:13:38.165
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:13:40.178
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:13:43.204
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:15:44.255
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:15:44.270
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:17:41.269
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:18:45.309
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:20:46.322
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:22:47.332
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:24:48.357
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:26:49.366
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:28:39.378
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:29:50.405
<129>klogd: rtl8651_user_pid set to 666 192.168.2.1 11/08 23:30:05.100
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:31:51.414
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:33:52.423
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:33:52.439
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:35:53.448
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:36:54.460
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:36:56.472
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:36:58.500
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:00.513
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:02.541
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:10.559
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:12.572
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:12.587
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:14.600
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:16.612
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:30.637
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:54.661
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:37:56.673
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:00.698
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:02.710
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:33.739
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:35.751
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:37.779
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:38:54.799
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:07.809
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:36.825
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:36.841
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:39.852
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:41.864
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:41.880
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:45.889
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:47.917
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:54.937
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:56.949
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:58.962
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:39:58.977
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:00.990
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:11.005
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:13.033
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:43.047
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:45.075
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:48.086
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:51.112
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:53.125
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:55.153
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:57.165
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:40:57.181
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:15.199
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:17.211
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:19.239
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:21.252
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:23.264
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:23.280
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:41:55.291
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:01.297
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:01.313
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:03.325
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:05.337
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:05.353
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:07.365
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:19.377
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:42:19.393
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:43:39.406
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:43:57.425
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:43:59.439
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:02.461
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:05.472
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:05.487
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:07.500
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:28.521
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:50.535
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:52.563
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:44:58.577
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:02.601
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:02.603
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:11.620
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:11.622
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:13.644
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:13.646
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:33.660
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:33.664
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:55.679
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:55.682
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:57.698
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:46:57.701
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:47:58.716
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:47:58.718
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:49:18.762
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:49:20.774
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:49:59.790
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:52:00.815
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:54:01.816
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:54:01.831
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:55:02.839
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:55:02.855
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:56:40.863
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:56:40.865
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:58:03.880
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 11/08 23:59:04.892
<129>klogd: rtl8651_user_pid set to 702 192.168.2.1 12/08 00:00:04.677
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:01:05.921
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:03:06.946
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:03:06.949
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:19.023
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:19.026
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:24.043
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:24.046
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:33.062
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:04:33.064
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:05:09.104
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:05:09.108
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:07:10.150
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:07:10.151
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:09:11.136
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:09:11.138
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:09:39.155
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:09:39.157
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:11:12.171
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:11:12.172
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:13:13.181
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:13:13.183
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:14:13.197
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:14:13.199
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:16:15.212
<129>klogd: Packet type : 0 -- free socket buffer only 192.168.2.1 12/08 00:16:15.213
<129>syslogd started: BusyBox v1.01 (2011.02.09-16:06+0000) 192.168.2.1 12/08 00:17:29.517
<129>klogd: klogd started: BusyBox v1.00-pre2 (2008.02.27-15:42+0000) 192.168.2.1 12/08 00:17:29.622
<129>klogd: SDRAM size: 32MB 192.168.2.1 12/08 00:17:29.655
<129>klogd: CPU revision is: 0000ff00 192.168.2.1 12/08 00:17:29.658
<129>klogd: Init MMU (16 entries) 192.168.2.1 12/08 00:17:29.661
<129>klogd: Primary instruction cache 0kB, linesize 0 bytes. 192.168.2.1 12/08 00:17:29.672
<129>klogd: Primary data cache 0kB, linesize 0 bytes. 192.168.2.1 12/08 00:17:29.675
) (gcc version 3.3.5) #423 Thu Feb 10 00:07:11 CST 2011 192.168.2.1 12/08 00:17:29.678
<129>klogd: Determined physical RAM map: 192.168.2.1 12/08 00:17:29.679
<129>klogd:  memory: 02000000 @ 00000000 (usable) 192.168.2.1 12/08 00:17:29.683
<129>klogd: NOFS reserved @ 0x8040b380 192.168.2.1 12/08 00:17:29.697
<129>klogd: On node 0 totalpages: 8192 192.168.2.1 12/08 00:17:29.699
<129>klogd: zone(0): 8192 pages. 192.168.2.1 12/08 00:17:29.722
<129>klogd: zone(1): 0 pages. 192.168.2.1 12/08 00:17:29.743
<129>klogd: zone(2): 0 pages. 192.168.2.1 12/08 00:17:29.747
<129>klogd: Kernel command line: root=/dev/mtdblock2 noinitrd 192.168.2.1 12/08 00:17:29.750
<129>klogd: IRR(0)=c0000000 192.168.2.1 12/08 00:17:29.783
<129>klogd: Calibrating delay loop... 199.06 BogoMIPS 192.168.2.1 12/08 00:17:29.786
<129>klogd: Memory: 28264k/32768k available (3056k kernel code, 4504k reserved, 124k data, 100k init, 0k highmem) 192.168.2.1 12/08 00:17:29.790
<129>klogd: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes) 192.168.2.1 12/08 00:17:29.794
<129>klogd: Inode cache hash table entries: 2048 (order: 2, 16384 bytes) 192.168.2.1 12/08 00:17:29.797
<129>klogd: Mount cache hash table entries: 512 (order: 0, 4096 bytes) 192.168.2.1 12/08 00:17:29.800
<129>klogd: Buffer cache hash table entries: 1024 (order: 0, 4096 bytes) 192.168.2.1 12/08 00:17:29.812
<129>klogd: Page-cache hash table entries: 8192 (order: 3, 32768 bytes) 192.168.2.1 12/08 00:17:29.815
<129>klogd: Checking for 'wait' instruction...  unavailable. 192.168.2.1 12/08 00:17:29.817
<129>klogd: POSIX conformance testing by UNIFIX 192.168.2.1 12/08 00:17:29.820
<129>klogd: NEW PCI Driver...isLinuxCompliantEndianMode=False(Big Endian) 192.168.2.1 12/08 00:17:29.822
<129>klogd: [PCI] Reset Bridge ..... Finish! 192.168.2.1 12/08 00:17:29.856
<129>klogd: Find Total 8 PCI functions 192.168.2.1 12/08 00:17:29.859
<129>klogd: Found 00:08 [1814/0401] 000280 00 192.168.2.1 12/08 00:17:29.892
<129>klogd: Linux NET4.0 for Linux 2.4 192.168.2.1 12/08 00:17:29.895
<129>klogd: Based upon Swansea University Computer Society NET3.039 192.168.2.1 12/08 00:17:29.897
<129>klogd: Initializing RT netlink socket 192.168.2.1 12/08 00:17:29.899
<129>klogd: Starting kswapd 192.168.2.1 12/08 00:17:29.902
) 192.168.2.1 12/08 00:17:29.953
<129>klogd: devfs: boot_options: 0x1 192.168.2.1 12/08 00:17:29.955
<129>klogd: Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher 192.168.2.1 12/08 00:17:29.958
<129>klogd: pty: 256 Unix98 ptys configured 192.168.2.1 12/08 00:17:29.961
<129>klogd: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SERIAL_PCI enabled 192.168.2.1 12/08 00:17:30.084
<129>klogd: Probing RTL8651 home gateway controller... 192.168.2.1 12/08 00:17:30.088
<129>klogd: Initialize RTL865x ASIC and driver 192.168.2.1 12/08 00:17:30.090
<129>klogd: chip name: 8651B, chip revid: 1 192.168.2.1 12/08 00:17:30.091
<129>klogd:    Initialize mbuf... 192.168.2.1 12/08 00:17:30.123
<129>klogd:    creating default 2 interfaces...eth0 IRR(6)=c0040000 192.168.2.1 12/08 00:17:30.125
<129>klogd: ===> Request IRQ 6 for eth0, ret=0 192.168.2.1 12/08 00:17:30.129
<129>klogd: eth1 ...OK 192.168.2.1 12/08 00:17:30.131
<129>klogd:    creating port0~port9 for 802.1d/1s/1w...0 1 2 3 4 5 6 7 8 ..OK! 192.168.2.1 12/08 00:17:30.152
<129>klogd: Hardware watchdog enabled 192.168.2.1 12/08 00:17:30.156
<129>klogd: PPP generic driver version 2.4.2 192.168.2.1 12/08 00:17:30.159
<129>klogd: PPP Deflate Compression module registered 192.168.2.1 12/08 00:17:30.162
<129>klogd: PPP BSD Compression module registered 192.168.2.1 12/08 00:17:30.248
<129>klogd: MPPE/MPPC encryption/compression module registered 192.168.2.1 12/08 00:17:30.282
<129>klogd: flash device: 800000 at be000000 192.168.2.1 12/08 00:17:30.286
<129>klogd:  Amd/Fujitsu Extended Query Table v1.1 at 0x0040 192.168.2.1 12/08 00:17:30.289
<129>klogd: number of CFI chips: 1 192.168.2.1 12/08 00:17:30.327
<129>klogd: cfi_cmdset_0002: Disabling fast programming due to code brokenness. 192.168.2.1 12/08 00:17:30.330
<129>klogd: Creating 5 MTD partitions on "Physically mapped flash": 192.168.2.1 12/08 00:17:30.516
<129>klogd: 0x00000000-0x00020000 : "boot" 192.168.2.1 12/08 00:17:30.519
<129>klogd: 0x00020000-0x007e0000 : "linux" 192.168.2.1 12/08 00:17:30.523
<129>klogd: 0x001512c0-0x007e0000 : "romfs" 192.168.2.1 12/08 00:17:30.525
<129>klogd: mtd: partition "romfs" doesn't start on an erase block boundary -- force read-only 192.168.2.1 12/08 00:17:30.528
<129>klogd: 0x007e0000-0x007f0000 : "bdinfo" 192.168.2.1 12/08 00:17:30.531
<129>klogd: 0x007f0000-0x00800000 : "cfg" 192.168.2.1 12/08 00:17:30.584
<129>klogd: Initializing Cryptographic API 192.168.2.1 12/08 00:17:30.587
<129>klogd: NET4: Linux TCP/IP 1.0 for NET4.0 192.168.2.1 12/08 00:17:30.590
<129>klogd: IP Protocols: ICMP, UDP, TCP, IGMP 192.168.2.1 12/08 00:17:30.615
<129>klogd: IP: routing cache hash table of 512 buckets, 4Kbytes 192.168.2.1 12/08 00:17:30.618
<129>klogd: TCP: Hash tables configured (established 2048 bind 4096) 192.168.2.1 12/08 00:17:30.622
<129>klogd: GRE over IPv4 tunneling driver 192.168.2.1 12/08 00:17:30.625
<129>klogd: klips_info:ipsec_init: KLIPS startup, Openswan KLIPS IPsec stack version: 2.4.5dr3 192.168.2.1 12/08 00:17:30.629
<129>klogd: klips_info:ipsec_alg_init: KLIPS alg v=0.8.1-0 (EALG_MAX=255, AALG_MAX=251) 192.168.2.1 12/08 00:17:30.633
<129>klogd: klips_info:ipsec_alg_init: calling ipsec_alg_static_init() 192.168.2.1 12/08 00:17:30.635
<129>klogd: ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0 192.168.2.1 12/08 00:17:30.638
<129>klogd: ipsec_aes_init(alg_type=14 alg_id=9 name=aes_mac): ret=0 192.168.2.1 12/08 00:17:30.640
<129>klogd: ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0 192.168.2.1 12/08 00:17:30.660
<129>klogd: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack 192.168.2.1 12/08 00:17:30.684
<129>klogd: ip_conntrack_pptp version $Revision: 1.1 $ loaded 192.168.2.1 12/08 00:17:30.687
<129>klogd: ip_nat_pptp version $Revision: 1.1 $ loaded 192.168.2.1 12/08 00:17:30.691
<129>klogd: ip_tables: (C) 2000-2002 Netfilter core team 192.168.2.1 12/08 00:17:30.734
<129>klogd: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. 192.168.2.1 12/08 00:17:30.737
<129>klogd: NET4: Ethernet Bridge 008 for NET4.0 192.168.2.1 12/08 00:17:30.742
<129>klogd: Bridge firewalling registered 192.168.2.1 12/08 00:17:30.746
<129>klogd: VFS: Mounted root (squashfs filesystem) readonly. 192.168.2.1 12/08 00:17:30.749
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:17:30.754
<129>klogd: Mounted devfs on /dev 192.168.2.1 12/08 00:17:30.756
<129>klogd: Freeing unused kernel memory: 100k freed 192.168.2.1 12/08 00:17:30.760
<129>klogd: IRR(4)=c0c40000 192.168.2.1 12/08 00:17:30.763
<129>klogd: ===> Request IRQ 4 for serial, ret=0 192.168.2.1 12/08 00:17:30.765
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:17:30.767
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:17:30.769
<129>klogd: rtl8651_user_pid set to 18 192.168.2.1 12/08 00:17:30.832
<129>klogd: Bring up ext  port 6.. 192.168.2.1 12/08 00:17:30.835
<129>klogd: Rx shift=10002 192.168.2.1 12/08 00:17:30.837
<129>klogd:  192.168.2.1 12/08 00:17:30.839
<129>klogd: Set IGMP Default Upstream interface (eth0) ... SUCCESS!! 192.168.2.1 12/08 00:17:30.840
<129>klogd: PPPoE Passthru disabled. 192.168.2.1 12/08 00:17:30.874
<129>klogd: Drop Unknown PPPoE PADT disabled. 192.168.2.1 12/08 00:17:30.877
<129>klogd: IPv6 Passthru disabled. 192.168.2.1 12/08 00:17:30.880
<129>klogd: IPX Passthru disabled. 192.168.2.1 12/08 00:17:30.920
<129>klogd: NETBIOS Passthru disabled. 192.168.2.1 12/08 00:17:30.953
<129>klogd: RTL865x Port 1 state=BLOCKING 192.168.2.1 12/08 00:17:30.957
<129>klogd: RTL865x Port 1 state=DISABLED 192.168.2.1 12/08 00:17:30.960
<129>klogd: device eth1 entered promiscuous mode 192.168.2.1 12/08 00:17:31.034
<129>klogd: RTL865x Port 1 state=BLOCKING 192.168.2.1 12/08 00:17:31.038
<129>klogd: br0: port 1(eth1) entering learning state 192.168.2.1 12/08 00:17:31.041
<129>klogd: RTL865x Port 1 state=LEARNING 192.168.2.1 12/08 00:17:31.125
<129>klogd: RTL865x VLAN STP disabled 192.168.2.1 12/08 00:17:31.128
<129>klogd: pcibios_enable_resources: already enabled when device probed. 192.168.2.1 12/08 00:17:31.172
<129>klogd: pci_request_regions: PCI regions already reserved 192.168.2.1 12/08 00:17:31.175
<129>klogd: pcibios_set_master: already done when device probed. 192.168.2.1 12/08 00:17:31.178
<129>klogd: IRR(5)=c0c40000 192.168.2.1 12/08 00:17:31.182
<129>klogd: ===> Request IRQ 5 for ra0, ret=0 192.168.2.1 12/08 00:17:31.185
<129>klogd: RT2661 Driver version - 1.1.0.0 192.168.2.1 12/08 00:17:31.189
<129>klogd: => Register External Device (ra0) vid (9) extPortNum (6) -- Dev (0x8119b200) 192.168.2.1 12/08 00:17:31.193
<129>klogd: register external ra0 device on extPort 6, id  1 192.168.2.1 12/08 00:17:31.195
<129>klogd: ra0 -- (rtl865x_extDev_registerUcastTxDev [660]) Register Unicast Tx Device [8119b200]. 192.168.2.1 12/08 00:17:31.198
<129>klogd: (rtl865x_extDev_regCallBack [845]) Register CallBack function -- Ucast Tx (c006177c) Free (c0061a10). 192.168.2.1 12/08 00:17:31.201
<129>klogd: src(0xc0a80201),broadip(0xc0a801ff) 192.168.2.1 12/08 00:17:31.252
<129>klogd: src(0x0),broadip(0xff) 192.168.2.1 12/08 00:17:31.254
<129>klogd: src(0x0),broadip(0xff) 192.168.2.1 12/08 00:17:31.256
<129>klogd: src(0x0),broadip(0xff) 192.168.2.1 12/08 00:17:31.258
<129>klogd: src(0x0),broadip(0xff) 192.168.2.1 12/08 00:17:31.261
<129>klogd: br0: port 1(eth1) entering forwarding state 192.168.2.1 12/08 00:17:31.293
<129>klogd: RTL865x Port 1 state=FWD 192.168.2.1 12/08 00:17:31.295
<129>klogd: br0: topology change detected, propagating 192.168.2.1 12/08 00:17:31.297
<129>klogd:  192.168.2.1 12/08 00:17:31.301
<129>klogd: @ = Add Host : [38:e7:d8:18:e5:98] VID 9 LinkID 1 PortNumber 6 192.168.2.1 12/08 00:17:31.303
<129>klogd: rtl8651_user_pid set to 386 192.168.2.1 12/08 00:17:32.880
<129>klogd: rtl8651_user_pid set to 441 192.168.2.1 12/08 00:17:41.239
<129>ipsec__plutorun: 104 "TunnelA" #1: STATE_MAIN_I1: initiate 192.168.2.1 12/08 00:17:44.431
<129>ipsec__plutorun: ...could not start conn "TunnelA" 192.168.2.1 12/08 00:17:44.458
<129>klogd: @ = Add Host : [bc:47:60:fe:d1:76] VID 9 LinkID 1 PortNumber 6 192.168.2.1 12/08 00:17:56.479
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:19:34.663
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:19:34.686
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:19:34.728
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:19:35.150
<129>klogd: emulate opcode 0x25 at 800f73b8  192.168.2.1 12/08 00:19:35.152
Looking at the logs and seen where the router detected a IP spoofing attach and smurf attack and then rebooted. Not sure if this is what causing the router to reboot sure does point in that direction. The smurf attach can cause a broadcast storm and actually freeze your router and cause a reboot.
Do you have a static ip address on your router?
Run a anti-virus and spy ware programs on all your computers in your network to rule out possible infection
After this is completed and more logs capture and router still rebooting please give us a call @ 1-866-606-1866 open a support case. After all this testing router still having an issue it could be a hardware issue which we would have to RMA unit.
Jasbryan
