11-09-2011 06:45 AM
i am looking at upgrading to this router
i would like to reserve some DHCP addresses, but i looked through the manual & didn't see it mentioned, but i did see it mentioned in 1 of the firmware upgrades
is it available?
mark
Solved! Go to Solution.
11-15-2011 11:18 AM
Yes, you can.
11-09-2011 06:47 AM
Mark, all RV series routers, including WRVS4400N, support this feature.
11-09-2011 06:57 AM
thanks for the quick answer
not sure if you can answer this one - i see the WRVS4400n and V2 for sale, is there a difference other than the VPN supported?
mark
11-09-2011 07:03 AM
WRVS4400N v1.1 and WRVS4400N v2 have the same features, although the underlined WiFi chips used are different.
The only practical difference is that the former was manufactured in earlier days.
11-15-2011 05:31 AM
i have the router now
can you please explain how to do it
i see how to enter fixed IP's, but i don't see how to reserve a DHCP address
i want the same MAC address to get the same IP from DHCP each time
mark
11-15-2011 07:02 AM
Does the router has the latest firmware? The Reserved DHCP feature is usually available as part of the DHCP Server configuration.
11-15-2011 07:16 AM
yes, just installed 2.0.2.1
mark
11-15-2011 11:14 AM
Please checkout the following page on the Web GUI.
Setup>LAN>Static IP Mapping
11-15-2011 11:17 AM
i used this to define a static address outside the normal DHCP range
i can define an address within the DHCP range?
mark
11-15-2011 11:18 AM
Yes, you can.
