WRVS4400N and VPN connection over AES-CBC (256 bits)...
Huexxx1977
at our office we have a brand new WRVS4400N with 2.0.1.3 fw preinstalled.
In order to make a VPN connection to our cliente, we need to establish an IPSEC VPN with AES-CBC encryption, but in the drop-down list I can only select 3DES.
Does v2.0.2.1 fw update include AES-CBC encryption?
In negative case, how can we add this type of encryption to the router?
Regards and thanks!
Te-Kai Liu
Level 7
Level 7
WRVS4400N does not support AES for VPN. You might want to consider RV220W or RV120W instead.
HI,
You will most likely need to move to enterprise small business products - as in the Small Business products the closest thing we have to block ciper IPSec vpn mode would be the SA500 series devices which can select AES-CCM & AES-GCM but not AES-CDC
Hope this is helpful
Jasbryan
