WRVS4400n - hacked?
mjwestkamper
We opened shop today to find the WRVS4400N was reset to defaults with two exceptions; it would allow WAN changes, and there was a HxtR service for port forwarding to 4192.
We had several VPN tunnels programed and no port forwarding. We had a non-standard DHCP as well as a custom LAN subnet.
Methinks the router has been hacked.
How can I tell if the firmware is not stock or the programming is corrupted?
I did the reset thing, however does that really erase everything?
Next, how can I reset this router to be ABSOLUTELY sure there is nothing afoot?
Any help will be really appreciated.
Mike
Tom Watts
Hello Mike,
You may reset the router by holding reset for 30 seconds using a pencil or paper clip or any non-damaging object.
You may log in to the router and go to Status -> Gateway to check the firmware version. You may upgrade to the latest code going to Admin -> Firmware upgrade.
You may download the latest code from the www.cisco.com. Type WRVS4400N firmware in the search box, click search. Navigate to 'software results'. The latest code is 2.0.2.1
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
