After updating our router with the latest firmware 2.0.1.3 that solved our current issues of unable to block url, our bandwidth reduced or degraded (from 100Mbps to 39Mbps) even though the IPS is disable. The technical specification of WRVS4400N shows 800Mbps with IPS disabled. If we disable the URL blocking, the bandwidth will return to what we subscribe with the speed of 100+Mbps. Anybody out there can advice on it. Thanks.
Rgds,
Raul
