06-23-2011 08:56 AM
I plan to deploy a number of routers here in Connecticut. The SNET, now part of AT&T allocates 5 static IP's. Actually 8 but only 5 are vailalbe to the user.
I can provide the topology and descrptiion. We've tried to make the 4400 work but to no avail. I hope someone here has experience with this topology and how to route the 5 IP's onto local LAN's with the 4400 or 4000.
Any direction will be greatly appreciated.
Mike
06-23-2011 03:00 PM
Mike,
Please post the topology and descrption;
So what are you trying to accomplish with the 4400 or 4000 ; i have alot of experience with both devices.
Give me as much details as possible.
thanks,
Jasbryan
Cisco Support Engineer
06-23-2011 04:51 PM
Here is an excellent writeup on the WAN side.
http://www.dslreports.com/faq/13591
I currenlty defaulted the router and the first ip is routed to my LAN.
What I am trying to do is connect one of the ip's to another local subnet or connect it to a specific local computer through the WRVS4400N.
Anything else I can provide - and heaps of thanks for any help you can offer.
Mike
06-23-2011 03:16 PM
Are you saying that each router is expected to handle 5 fixed public IP addresses on behalf of the computers in the LAN of the router? If so, you need a different router - WRVS4400N does not support 1-to-1 NAT.
Edit: Among the small business routers, RV0xx, RV120W, and RV220W support 1-to-1 NAT.
06-23-2011 04:51 PM
Mike
06-23-2011 05:28 PM
Mike,
I understand what you are trying to do
The RVS4000/WRVS4400N are not going to be able to do what you need it to do.
I would look at the RV042, RV082 or the SA520/540 routers, they have the ability to 1 to 1 NAT the public IP to an internal IP address.
Example would be 97.65.143.1 to 97.65.143.4 are your routable IP's
with .1 going to the router 192.168.1.1
.2 going to a web server 192.168.1.2
and so on
I hope this answers your question
06-23-2011 07:47 PM
Thanks, I will try to find one locally and give it a go.
Thanks for your assist. When I get it working I'll pop back in and click the button.
Mike
