3925 basic config
kram106
Frequent Visitor
Frequent Visitor
I am trying to get this thing to have internet from GE0/0 available in the LAN connected to GE0/2 and am probably missing something stupid. I am able to ping google from the router but not from a computer on the LAN.
version 15.2
service config
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.10.1
ip dhcp pool default
import all
network 192.168.0.0 255.255.0.0
dns-server 192.168.1.1
default-router 192.168.1.1
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
no ip ftp passive
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-WAN$
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
ip address 192.168.1.1 255.255.0.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 remark INSIDE_IF=GigabitEthernet0/2
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
end
Thanks!
kram106
Frequent Visitor
Frequent Visitor
Hi all, Thank you for your help. I ended up changing the local ip range to 172.16.0.0 255.255.0.0, internet modem plugs into G0/1, and the LAN switch plugs to G0/2. The range 172.16.1.2 172.16.1.254 is excluded for servers with a static ip. For future reference, here is my working config:
version 15.2
service password-encryption
hostname cisco1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.254
ip dhcp pool sdm-pool1
import all
network 172.16.0.0 255.255.0.0
default-router 172.16.1.1
no ip domain lookup
no ipv6 cef
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/1
ip nat outside
duplex auto
speed auto
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 172.16.1.1 255.255.0.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit 172.16.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
transport input all
end
8 Replies 8
balaji.bandi
Quick Look
your interface address referring :
ACL referring :
This is not matched.
to match your interface IP range change the acl as below and test and advice
config t
no access-list 1 permit 192.168.0.0 0.0.255.255
access-list 1 permit 192.168.1.0 0.0.255.255
change DHCP reservation pool also
BB
luis_cordova
Hi @kram106,
I think you are missing two things:
1- A default route
ip route 0.0.0.0 0.0.0.0 g0/0
2- If you are going to use the DNS of Google, you must indicate in your DHCP pool that this will be the dns:
dns-server 8.8.8.8
@balaji.bandi - think again about your suggestion to use this
when the mask is 0.0.255.255 then IOS will ignore the third octet and the config will become
I believe that @luis_cordova has identified the issue correctly as relating to the default route. But I do not agree with his suggested solution
instead I suggest this
ip route 0.0.0.0 0.0.0.0 dhcp
A static route specifying only the outbound interface, where that interface is Ethernet, is problematic. A better solution is to configure the default route as originating from DHCP.
Rick
Rick
@Richard Burts  good catch may be my typo...
BB
Hello Richard,
very good notes rated as it deserves.
a default static route like
ip route 0.0.0.0 0.0.0.0 gi0/0
relies on proxy ARP enabled on the upstream router (that can be enabled or not)
and creates scalability issues as it will cause an ARP request for each internet destination address making the ARP table to grow over time.
Edit:
Balaji is correct about the need to resize the DHCP pool to reflect the effective subnet on the gi0/2 interface.
Hope to help
Giuseppe
@balaji.bandi easy mistake to make. And frankly I wonder whether the original config of the interface
really intended to use the /16 mask or if that was a typo. But if that is the mask of the interface then 0.0.255.255 needs to be the mask of the acl.
@Giuseppe Larosa yes those were some of the aspects I had in mind when I said that static route specifying only the outbound interface was problematic. I see more and more frequently networks which disable proxy arp because of the potential security issues. Thanks for the rating.
Rick
Rick
cheers and noted both notes..
waiting for the orginal poster feedback.
BB
kram106
Frequent Visitor
Frequent Visitor
version 15.2
hostname cisco1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
import all
no ip domain lookup
no ipv6 cef
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
transport input all
end
