adding banners
jose.jimenez
Level 3
Level 3
Can someone please show me how to add a banner "welcome" message to a router??
Is it conf t? to add it and is it one line at a time that I need to add or can I add the entire message by typing it in and cntl z, write? Here's the message I'd like to insert.
*****Your contact number is (123)456-7890
*****Welcome to the Parks Network!
*****This router is the property Parks Network
*****Use of this network device is restricted to our network team;
*****Unauthorized access and/or use is prohibited!
Thanks for help!
royalblues
Level 11
Level 11
The syntax for the banner command is:
banner motd {char} {banner text} {char}
where the char is the delimiting character..
you can configure
config t
Banner motd #
** Your contact number is (123)456-7890 **
** Welcome to the Parks Network! **
** This router is the property Parks Network **
** Use of this network device is restricted to our network team; **
** Unauthorized access and/or use is prohibited! **
http://www.ciscopress.com/content/images/1587131595/samplechapter/1587131595content.pdf
Narayan
Thank you Narayan, Once I add this message and save it, how do I go in and modify or remove phone number or name?
Just Edit the phone number in your notepad. Then re paste your message again. In you configuration the # is the breaker. As long as you have no # within your message before the last character which marks the end of message, you should be fine
