Bandwidth Command
intertouch
Community Member
I have 1 unit of Cisco Catalyst 2950 switch.
1 PC connected to port 23 and another one
connected to port 24.
hostname switchA
int fa0/23
bandwidth 128
int fa0/24
bandwidth 128
when i am doing a ftp, I found out that the
speed is more than 128k? why?
shijogeorge
Level 5
Level 5
Bandwidth command is used only for communicating the interface bandwidth value to higher lever protoclos. eg: Routing protols which use bandwidth as a parameter for calculating metric takes this value if configured.
This command won't affect the actual bandwidth of the physical interface.
Shijo George.
Hi;
If you want to limit the traffic 128K on FE port, then you may use Committed Access Rate definitions such as;
rate-limit input 128000 16000 32000 conform-action transmit exceed-action drop
rate-limit output 128000 16000 32000 conform-action transmit exceed-action drop
This conf. will limit the traffic
Baris.
Can this command supported by Cisco Catalyst 2950 with standard image?
Hi;
I missed the part that you use 2950 switches. As it is L2 switch, this conf. does not work on it besides there is not such a support with standart images as far as i have known. You may limit the bandwith on L3 side via CAR.
