Basic Router Setup
JLVB83
Level 2
Level 2
Hello folks newbie here I've got a Cisco 1921 that my office chucked because of upgrades, I'm just trying to set it up as a basic router (while learning what I can in the process).  Basically want Gi0/0 to be my WAN port and Gi0/1 to be the LAN port.  I will post my config file feel free to critique it, basically most of it is me searching this forum and trying config option and seeing what they do, I just can't seem to get traffic from my LAN port to get past or through the WAN port.  My WAN port can hit the internet and ping everything.  Any help will be appreciated.
Using 2365 out of 262136 bytes
! Last configuration change at 17:56:08 UTC Sat Aug 29 2020
! NVRAM config last updated at 17:56:11 UTC Sat Aug 29 2020
version 15.1
service config
hostname JLVBCISC1921
boot-start-marker
boot-end-marker
enable secret 5 $1$LP8J$do7T.2ozAnQNXiGyRzWKq.
enable password Canada2004
no aaa new-model
no ipv6 cef
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool JLVB
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
license udi pid CISCO1921/K9 sn FGL160720QS
redundancy
interface Loopback1
ip address 1.2.3.4 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0/0
no ip address
no mop enabled
interface FastEthernet0/0/1
no ip address
shutdown
interface FastEthernet0/0/2
no ip address
shutdown
interface FastEthernet0/0/3
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT-Gi interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.0.1 90
ip route 0.0.0.0 0.0.0.0 192.168.0.1 254
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp 90
access-list 100 permit ip any any
no cdp run
route-map NAT-Gi permit 10
match ip address 100
match interface GigabitEthernet0/0
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password **********
login
transport input all
scheduler allocate 20000 1000
end
Responding to the new config:
- This config contains a line
no ip routing
This will disable ip routing. You need to enter the command
ip routing
Note that when you do this the running config will not contain the line ip routing, but that is because ip routing is the default and most of the time default values do not show up in the running config.
- I do not see any routing statements, most especially no default route is configured. It might look something like
ip route 0.0.0.0 0.0.0.0 Gi0/0 dhcp
- I do not see any address translation. It might look some like
int Gi0/0
ip nat outside
int Fi0/1
ip nat inside
ip nat inside source list 1 interface Gi0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
- I suggest that you remove this line
This line will be ignored since you have also configured enable secret. Enable secret is a more recent enhancement and is more secure than enable password. If both commands are entered then the enable password command will be ignored. Since it is not useful I suggest that you remove it.
- I do not think that you need the line
service config
so I suggest that you remove it.
- your config contains the line
no ip cef
I suggest that cef is generally a good thing and unless you have a particular reason to remove it that cef should be enabled.
Rick
9 Replies 9
Martin L
Looks good; couple questions: what or where is 192.168.0.1 90?  is it cable/internet modem?
I am not sure about using route-map with NAT; just use dynamic NAT mapping with list 100, ip nat inside source list 100 interface GigabitEthernet0/0 overload
192.168.0.1 is my ISP router, I don't know what the 90 part actually does, I've been copying config settings from other post trying stuff out so its very likely some stuff in my config does not need to exist at all like using the route-map NAT was just trying stuff to see if it worked i will look into this "dynamic NAT mapping with list 100, ip nat inside source list 100 interface GigabitEthernet0/0 overload" now
thks
your 192.168.0.1 is my ISP router does not know how to reach internal network of 1921 router, 192.168.1.0 /24
you need to add static route on that ISP box. what is it btw?
Richard Burts
There are several things about your config that I would comment on:
- you have configured this
Using a route map for address translation introduces complexity into the configuration. And I see no reason why a route map is called for here. The typical reason for using a route map with address translation is that there are more than 1 outbound interfaces that need to do address translation. And that is not the case here. A more simple approach would be better.
- the access list that you use is:
why are you using an extended access list? Most of the time for address translation a standard access list that specifies the inside subnets is sufficient. Using an extended acl suggests that you want to make decisions based on either destination address or on port selection. But your acl does neither of these. Again more simple is better than more complex.
- you have configured 3 default routes
and I do not know why you have done this. 2 of the 3 define that the next hop is 192.168.0.1. Since Gig0/0 is specified to learn its IP using DHCP the address could potentially change. But these static routes are static. If the learned IP address changed then these static routes would not work. The better approach is to specify a default route using the interface and dhcp option as this one does
I am puzzled why you are using 90 in the configuration of this route. This typically suggests a backup route. But it looks to me that this should be your primary default route.
It is not related to the main question of this post but I would like to comment on these parts of your configuration
enable password was the earliest implementation of a password for enable mode. And it turns out to not be very secure. enable secret  was a newer approach and was more secure. If both type of passwords are present in the configuration then the device will use the values in enable secret and ignore the values in enable password. So why have both?  And I surely hope that the password that you used for enable secret is not "Canada2004". Since specifying no service password-encryption means that your enable password in now exposed for everyone to see.
- You have disabled cdp. Is there a reason for that? I can understand disabling cdp on the outside interface. But why disable it globally?
Rick
Hey Rick thks for the info i will look into a lot of the stuff you just posted, the short answer for most your why have you done this or why config it this way, is just trying things I've found and seen in this forum much of it may be completely wrong, too complex or unnecessary, just trying to learn stuff by trial and error.  Basically I want to start with a basic setup one WAN port and one LAN port, I want the LAN port to have a DHCP and be able to access the internet through the WAN port and then build from there.  As it stands I can't seem to ping the outside word from the PC I have on the LAN port.
thks
JLVB83
Level 2
Level 2
OK so blanked the Router did a few basic config's, what do I need to do so my PC on Gi0/1 can ping the outside word on the WAN port of Gi0/0
Using 1831 out of 262136 bytes
! Last configuration change at 21:16:02 UTC Sat Aug 29 2020
! NVRAM config last updated at 21:16:04 UTC Sat Aug 29 2020
version 15.1
service config
hostname CISCO1921
boot-start-marker
boot-end-marker
enable secret 5 $1$/0B2$70QjVhO/f1tneOFaYcuUl0
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip dhcp pool JLVB
redundancy
no ip address
no ip route-cache
shutdown
ip address dhcp
no ip route-cache
duplex auto
speed auto
no ip route-cache
duplex auto
speed auto
no ip address
no mop enabled
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password Canada2004
login
transport input all
end
no ip routing
ip routing
int Gi0/0
ip nat outside
int Fi0/1
ip nat inside
service config
no ip cef
Rick
Thank you so much Rick those were the base level configs I needed, I now know were to start and move forward with testing and playing with this cisco stuff.
thks Folks
I am glad that my suggestions have been helpful. I think that you have a good approach, to start with simple basic configs, get them to work, and then incrementally add other things to the config. There is a lot to learn and I believe that you are making a good start. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
