BGP Errors
azago
Frequent Visitor
Frequent Visitor
Mar 26 19:32:39.557 GMT-3: %BGP-5-ADJCHANGE: neighbor X.X.X.X Up
Mar 26 19:32:40.741 GMT-3: %BGP-5-ADJCHANGE: neighbor X.X.X.X Down BGP Notification sent
Mar 26 19:32:40.741 GMT-3: %BGP-3-NOTIFICATION: sent to neighbor 200.219.130.253 3/11 (invalid or corrupt AS path) 13 bytes 40020A02 041F776F D11C8200 47
Mar 26 19:32:40.741 GMT-3: BGP: X.X.X.X Bad attributes FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 003C 0200 0000 2140 0101 0040 020A 0204 1F77 6FD1 1C82 0047 4003 04C8 DB82 06C0 0706 0047 1060 B336 140F E3F0
Does anyone knows were the problem could be?
Alexandre,
Your configuration confirms what I thought. The neighbor sends you an AS-PATH with 8055 as the first ASN, while the peer ASN is 64548. Note that "remove-private-as" is only effective for outbound messages, so doesn't apply here.
Just out of curiosity, what type of device is the neighbor. Route server? In which case in might be ok to accept the update.
If you want to accept the updates despite the first ASN in the AS-PATH doesn't match the peer ASN, you can disable this check with the following command:
router bgp xxx
no bgp enforce-first-as
Hope this helps,
Alexandre,
The hexadecimal characters are actually a dump of the BGP message for which IOS considers the AS-PATH to be either invalid or corrupted.
After decoding the BGP message, the AS-PATH doesn't seem to be corrupted.
IOS would declare the path invalid if the first in the AS path number (last AS traversed) is not equal to the peer AS number. According to the decoded message, this ASN should be 8055. Does it match the peer ASN?
Also what version of IOS are you running on this router?
Hope this helps,
Hi The IOS is sup-bootdisk:s72033-advipservicesk9_wan-mz.122-18.SXF7.bin and the config are
neighbor REGISTRO remote-as 64548
neighbor REGISTRO shutdown
neighbor REGISTRO update-source GigabitEthernet1/1.854
neighbor REGISTRO next-hop-self
neighbor REGISTRO remove-private-as
neighbor REGISTRO route-map REGISTRO_BR_AS64548_IN in
neighbor REGISTRO route-map REGISTRO_BR_AS64548_OUT out
neighbor REGISTRO maximum-prefix 5000
neighbor X.X.X.X peer-group REGISTRO
neighbor X.X.X.X soft-reconfiguration inbound
Alexandre,
router bgp xxx
Hope this helps,
