External Calling
Alex.Smith.1433
Community Member
Hi I'm trying to enable external calls currently I can call internally and receive external however I want to be able to phone out on one if not all phones connected to the network.
Below is my current config:
Building configuration...
Current configuration : 5655 bytes
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
ip dhcp excluded-address 192.168.0.1 192.168.0.50
ip dhcp excluded-address 192.168.0.241 192.168.0.255
ip dhcp pool PHONES
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 192.168.0.5 192.168.0.6
 option 150 ip 192.168.0.17
ip cef
no ipv6 cef
isdn switch-type basic-net3
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 192.168.0.0 255.255.255.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 modem passthrough nse codec g711ulaw
 h323
  h245 tunnel disable
 sip
  bind control source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 3600
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g729br8
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 4
  call start fast
voice hunt-group 1 longest-idle
 timeout 0
license udi pid CISCO2901/K9 sn FGL173220Y3
license accept end user agreement
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address 192.168.0.17 255.255.255.0
 duplex auto
 speed auto
interface ISM0/0
 description Unity-Express-Module
 ip unnumbered GigabitEthernet0/0
 ip virtual-reassembly in
 service-module ip address 192.168.0.10 255.255.255.0
 !Application: CUE Running on ISM
 service-module ip default-gateway 192.168.0.17
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 no ip address
interface BRI0/0/0
 no ip address
 isdn point-to-point-setup
interface BRI0/0/1
 no ip address
interface BRI0/1/0
 description Test_ISDN_1
 no ip address
 isdn overlap-receiving
 isdn layer1-emulate network
 isdn incoming-voice voice
 isdn static-tei 0
interface BRI0/1/1
 no ip address
interface BRI0/2/0
 no ip address
interface BRI0/2/1
 no ip address
interface BRI0/3/0
 no ip address
interface BRI0/3/1
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.0.10 255.255.255.255 ISM0/0
control-plane
voice-port 0/0/0
 no vad
 compand-type a-law
 no comfort-noise
 cptone GB
 description TEST_ISDN
voice-port 0/0/1
 input gain -6
 output attenuation -6
 echo-cancel coverage 64
 no vad
 compand-type a-law
 no comfort-noise
 cptone GB
 timeouts interdigit 6
 description ***2BRI-NT/TE Port***
 bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2 voip
 destination-pattern 1[0-9][0-9][0-9]
 session target ipv4:162.168.0.17
dial-peer voice 1 pots
 destination-pattern 9.
 port 0/0/0
 forward-digits all
dial-peer voice 3 pots
 destination-pattern 9T
 port 0/0/1
gatekeeper
 shutdown
telephony-service
 max-ephones 20
 max-dn 200
 ip source-address 192.168.0.17 port 2000
 network-locale GB
 load 7906 term11.default
 load 7960-7940 P0030801SR02
 load 6921 SCCP69xx.9-2-1-0
 load 6941 SCCP69xx.9-2-1-0
 max-conferences 8 gain -6
 web admin system name alex secret 5 $1$eSOq$7L1LD5IBwR3F5v0.3gc3i1
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
 number 1001
 name ***Black 6941 ***
ephone-dn  2
 number 1002
 name ***6921 v1***
ephone-dn  3
 number 1003
 name ***6921 v2***
ephone-dn  4
 number 1004
 name ***Big Bertha***
ephone  1
 mac-address E8B7.484E.8483
 type 6941
 button  1:1
ephone  2
 mac-address 8478.ACC7.13C0
 type 6941
 button  1:2
ephone  3
 mac-address 8478.ACC7.13A4
 type 6921
 button  1:3
ephone  4
 mac-address 0023.5E18.A3AA
 type 7940
 button  1:4
ephone-hunt 1 longest-idle
 pilot 619879
 list 1001, 1002, 1003
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
2 Accepted Solutions
kevin.blackburn
Basically you need a dial peer setup for outside calls.
Take a look at this page: http://routerjockey.com/2009/09/08/cisco-voip-basics-cisco-dial-plans/
That will allow you to call out.
For instance, this would allow for calls out with a 10 digit, outside number:
dial-peer voice 100 pots
 description outbound dialpeer 1
 preference 7
 destination-pattern 1[2-9].........
 port 2/0
 forward-digits all
Hope that helps!
^Edit - probably should have mentioned that will need to be adapted to your location as far as port number, etc. That is a pull from one of my setups. Thanks
You will need a specific dial peer for your situation. What number are you dialing in order to dial outside numbers? Your destination pattern will need to include the exit digit as well as 10 digits or wildcards. For example: "destination-pattern 9.........." would mean that you dial 9 to get an outside line then any 10 digits that follows would be allowed. This link has a few examples:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
Also make sure you are only sending the service provider 10 digits. "forward-digits 10"
You may also want to check with your service provider to make sure you are allowed to dial out on those lines.
Good Luck.
kevin.blackburn
 preference 7
 port 2/0
 forward-digits all
Hope that helps!
Have tried adding however still getting an engaged tone. Below is my latest config can anyone help?
Current configuration : 5860 bytes
! Last configuration change at 10:37:45 UTC Wed Jan 21 2015
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool PHONES
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
 dspfarm
voice rtp send-recv
voice service voip
 redirect ip2ip
 h323
  h245 tunnel disable
 sip
voice class codec 1
voice class h323 1
  call start fast
 timeout 0
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 no ip address
interface BRI0/0/0
 no ip address
interface BRI0/0/1
 no ip address
interface BRI0/1/0
 no ip address
 isdn static-tei 0
interface BRI0/1/1
 no ip address
interface BRI0/2/0
 no ip address
interface BRI0/2/1
 no ip address
interface BRI0/3/0
 no ip address
interface BRI0/3/1
 no ip address
interface Vlan1
 no ip address
no ip http server
control-plane
voice-port 0/0/0
 no vad
 compand-type a-law
 no comfort-noise
 cptone GB
voice-port 0/0/1
 input gain -6
 no vad
 compand-type a-law
 no comfort-noise
 cptone GB
 bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
 port 0/0/0
 forward-digits all
 port 0/0/1
 preference 7
 port 0/0/0
 forward-digits all
gatekeeper
 shutdown
telephony-service
 max-ephones 20
 max-dn 200
 network-locale GB
 dn-webedit
 time-webedit
ephone-dn  1
 number 1001
ephone-dn  2
 number 1002
 name ***6921 v1***
ephone-dn  3
 number 1003
 name ***6921 v2***
ephone-dn  4
 number 1004
ephone  1
 type 6941
 button  1:1
ephone  2
 type 6941
 button  1:2
ephone  3
 type 6921
 button  1:3
ephone  4
 type 7940
 button  1:4
 pilot 619879
line con 0
line aux 0
line 2
 no exec
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
end
Good Luck.
