force use proxy
bkoum
Level 3
Level 3
Hello, is there any way to force user to pass throught a proxy server using a L3 switch?
thanks
2 Accepted Solutions
simontibbitts
Level 7
Level 7
Hello.
This is what WCCP is designed for. You can read about it here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_44_se/configuration/guide/swwccp.html
A much more messy approach (and probably unscalable) would be to use policy routing on your switch to divert all web traffic to your proxy server (if your switch supports PBR)
Kind Regards
Simon
Hello.
This wiki link lists some vendors that support it
http://en.wikipedia.org/wiki/Web_Cache_Communication_Protocol
It does not list ISA but you could always ask the vendor.
Simon
5 Replies 5
paolo bevilacqua
Yes, use an ACL.
simontibbitts
Level 7
Level 7
Hello.
Kind Regards
Simon
does WCCP can cooperate using an ISA server as proxy machine or can work only with cisco systems ?
Hello.
Simon
