Higher than expected CPU Utilization on C2821
p-blake
Level 2
Level 2
I am experiencing a higher than expected CPU Utilization on a 2821 router at one of my remote locations.  Can anyone explain what DHCPD Dynamic Up is, if it is necessary and how to shut it off if it can be shut down?
Thanks..
Router#sho proc cpu | exclude 0.00%
CPU utilization for five seconds: 35%/2%; one minute: 35%; five minutes: 35%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  38       50948   1783302         28  0.08%  0.07%  0.08%   0 Per-Second Jobs
  66     2536868   9963641        254  0.16%  0.09%  0.08%   0 IP Input
  91         604   2638259          0  0.08%  0.03%  0.02%   0 CEF process
139     72262761432835246          5 32.09% 32.16% 32.15%   0 DHCPD Dynamic Up
141        1544  55719564          0  0.08%  0.08%  0.08%   0 PPP manager
142        1292  55719889          0  0.08%  0.06%  0.08%   0 PPP Events
151        1764  55710601          0  0.08%  0.06%  0.08%   0 RADIUS
152        2856      2667       1070  0.16%  0.12%  0.04% 322 Virtual Exec
Router#show proc mem | inc DHCP
  72   0      30372        444      28904          0          0 DHCPD Receive
101   0          0          0       7008          0          0 DHCPD Timer
131   0     746484     542856      77808      11340          0 DHCPD Database
139   0      24924          0       7256          0          0 DHCPD Dynamic Up
Router#show proc cpu | include DHCPD
  72         152     16060          9  0.00%  0.02%  0.00%   0 DHCPD Receive
101           0        67          0  0.00%  0.00%  0.00%   0 DHCPD Timer
131         324      4382         73  0.00%  0.00%  0.00%   0 DHCPD Database
139     74759921481245977          5 32.17% 32.10% 32.22%   0 DHCPD Dynamic Up
14 Replies 14
Giuseppe Larosa
Hello P-Blake,
it should be related to DHCP server
are defined DHCP local pools on the router ?
Hope to help
Giuseppe
Yes, there are 2 local pools that seem to be functioning normally.
The router was re-loaded on 2/18/10 and the DHCP Dynamic process went away until between 0400 and 0500 this morning and now the router is back to a constant 40% cpu.
show proc cpu sort | exc 0.00%
CPU utilization for five seconds: 35%/2%; one minute: 36%; five minutes: 36%
  31    14742948-1292143477          0 32.09% 32.77% 32.85%   0 DHCPD Dynamic Up
  38        4768    563644          8  0.08%  0.07%  0.08%   0 Per-Second Jobs
152         752  17610558          0  0.08%  0.07%  0.08%   0 RADIUS
141        5932  17613065          0  0.08%  0.09%  0.08%   0 PPP manager
  66      510880   1962112        260  0.08%  0.09%  0.08%   0 IP Input
I do not see this process on any of my other routers.
Any suggestions on what this process is doing and how to resolve it?
Thanks..
p-blake
Level 2
Level 2
Thanks..
paolo bevilacqua
Which exact IOS are you running ?
#show ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(17b), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Tue 26-Feb-08 01:47 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
C2821-Vandercook_TMC uptime is 6 days, 13 hours, 2 minutes
System returned to ROM by reload at 21:45:37 EST Wed Feb 17 2010
System restarted at 21:46:20 EST Wed Feb 17 2010
System image file is "flash:c2800nm-ipbasek9-mz.124-17b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 2821 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FTX1141A3JS
2 Gigabit Ethernet interfaces
4 Serial interfaces
4 Channelized T1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
If
Cisco
Any chance that you have an infected PC on network? Do you have a switch to monitor a suspicios number of broadcasts or other anomaly ?
not seeing other degradation.  No unusually high broadcast or other
problems.
What command triggers this process to start?
Unlikely that a process goes and sustains without reason.
Recommend you turn some dhcp server debugging to buffer (not console, not terminal) and check for rogue requests coming in.
Below is a section of the log with DEBUG IP DHCP SERVER EVENTS turned on.  Certainly doesn't look as though the router is overwhelmed with DHCP requests.
Router#sho log
Syslog logging: enabled (1 messages dropped, 1 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 6092 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 4659 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 109 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 207 message lines logged
        Logging to 10.16.1.16(global) (udp port 514, audit disabled,  link up),
207 message lines logged, xml disabled,
               filtering disabled
        Logging to 10.2.74.200(global) (udp port 514, audit disabled,  link up),
               filtering disabled
Log Buffer (65535 bytes):
Feb 24 12:27:16: %SYS-5-CONFIG_I: Configured from console by blakep on vty0 (10.
112.21.72)
Feb 24 12:28:15.194: DHCPD: checking for expired leases.
Feb 24 12:30:15.197: DHCPD: checking for expired leases.
Feb 24 12:32:15.200: DHCPD: checking for expired leases.
Feb 24 12:34:15.203: DHCPD: checking for expired leases.
Feb 24 12:35:56.342: DHCPD: Sending notification of ASSIGNMENT:
Feb 24 12:35:56.342:  DHCPD: address 172.18.4.73 mask 255.255.255.0
Feb 24 12:35:56.342:   DHCPD: htype 1 chaddr 0016.eab3.86f8
Feb 24 12:35:56.342:   DHCPD: lease time remaining (secs) = 2592000
Feb 24 12:36:15.207: DHCPD: checking for expired leases.
Feb 24 12:37:41.661: DHCPD: writing bindings to ftp-server
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.73.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.74.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.80.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.81.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.83.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.87.
Feb 24 12:37:44.185: DHCPD: writing address 172.18.4.88.
Feb 24 12:37:44.401: DHCPD: writing address 172.18.4.89.
Feb 24 12:37:44.401: DHCPD: writing address 172.18.4.90.
Feb 24 12:37:44.401: DHCPD: writing address 172.18.4.95.
Feb 24 12:37:44.401: DHCPD: writing address 172.18.4.98.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.100.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.101.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.102.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.103.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.104.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.105.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.106.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.108.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.110.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.111.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.113.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.114.
Feb 24 12:37:44.405: DHCPD: writing address 172.18.4.115.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.116.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.118.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.121.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.123.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.129.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.130.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.131.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.132.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.137.
Feb 24 12:37:44.413: DHCPD: writing address 172.18.4.163.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.4.181.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.4.185.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.4.192.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.68.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.70.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.71.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.73.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.77.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.80.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.81.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.84.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.86.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.87.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.88.
Feb 24 12:37:44.417: DHCPD: writing address 172.18.41.89.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.90.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.92.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.93.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.94.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.95.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.96.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.98.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.100.
Feb 24 12:37:44.421: DHCPD: writing address 172.18.41.101.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.103.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.104.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.105.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.106.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.107.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.108.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.109.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.110.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.111.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.112.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.113.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.114.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.115.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.116.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.117.
Feb 24 12:37:44.425: DHCPD: writing address 172.18.41.118.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.119.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.120.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.121.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.122.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.123.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.124.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.125.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.126.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.127.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.128.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.129.
Feb 24 12:37:44.429: DHCPD: writing address 172.18.41.130.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.131.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.132.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.133.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.134.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.135.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.136.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.137.
Feb 24 12:37:44.433: DHCPD: writing address 172.18.41.138.
Feb 24 12:37:44.453: DHCPD: wrote automatic bindings to ftpserver.
Feb 24 12:38:15.210: DHCPD: checking for expired leases.
Feb 24 12:40:15.213: DHCPD: checking for expired leases.
Feb 24 12:42:15.216: DHCPD: checking for expired leases.
Router#
So you haven't any config like ftp ?
not sure what you are asking.  I sanitized the output just to indicate that the in
formation was transfered to the FTP server.
I do not see any config of your. What I'm saying, if router is trying to save DHCP status, some config must be telling it to do so.
Yes,  The router writes the DHCP database to the FTP server at regular intervals.
#show ip dhcp database
URL      : ftp://anonymous:router@10.16.1.19/router-dhcp
Read     : Feb 24 2010 09:24 AM
Written  : Feb 24 2010 01:04 PM
Status   : Last write succeeded. Agent information is up-to-date.
Delay    : 120 seconds
Timeout  : 300 seconds
Failures : 0
Successes: 30
Disable that for a try.
