Incrementing overrun input errors on interface
dhananjay95929
Level 2
Level 2
Hello Support Community,
I am seeing incrementing "overrun" type of input errors on a FastEthernet interface on a Cisco 3845 series router. I am well aware of the fact that overrun errors MAY BE caused due to "input rate exceeding the rate at which the interface receiver hardware can write the packets to the hardware buffer" as per Cisco documentation. However, the input rate on this interface averages at around 1.5 Mbps and the output rate averages at around 500 kbps. Here's what the interface statistics look like from a monitoring perspective.
ReceiveTransmit
Interface Bandwidth100.0 Mbps 100.0 Mbps
Current Traffic1.503 Mbps 412.542 kbps
Percent Utilization2 % 0 %
Packets per Second849.0 pps 512.0 pps
Average Packet Size221 bytes 101 bytes
The network topology is as follows:
[3845 router [Fa3/0]]------------[[Gi5/2] CAT4500 switch]
Speed and duplex on both sides of the link are set to 100 and full respectively. There are no errors on the CAT 4500 switch side of the link. I increased the hold-queue input size on the 3845 router side interface from the default 75 to 2048 in an effort to see if it stops the incrementing errors but it did not.
I am also seeing the total output drop counter rising gradually. The input errors counter rises much much faster than the output drop counter though.
sh int fa3/0
FastEthernet3/0 is up, line protocol is up
  Hardware is AmdFE, address is 0013.7f72.6001 (bia 0013.7f72.6001)
  Description: Int-to-Customer Network
  Internet address is 10.0.1.251/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 254/255, txload 1/255, rxload 6/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:23:54
  Input queue: 0/2048/0/0 (size/max/drops/flushes); Total output drops: 259
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2424000 bits/sec, 906 packets/sec
  5 minute output rate 450000 bits/sec, 535 packets/sec
     4890108 packets input, 1761777920 bytes
     Received 7578 broadcasts, 0 runts, 0 giants, 0 throttles
     54709 input errors, 0 CRC, 0 frame, 54709 overrun, 0 ignored
     0 watchdog
     2920904 packets output, 313102254 bytes, 0 underruns
     0 lost carrier, 0 no carrier
sh int fa3/0 accounting
FastEthernet3/0 Int-to-Customer Network
                Protocol    Pkts In   Chars In   Pkts Out  Chars Out
                   Other        374      19822       1129      67740
                      IP   11394712   76208123    6874875  730544863
                 DEC MOP          0          0         20       1540
                     ARP       4962     297720          7        420
sh int fa3/0 switching
          Throttle count          0
                   Drops         RP         18         SP          0
             SPD Flushes       Fast         66        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs   56666977      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process  754269402  562447667 1038407414 1891734184
            Cache misses         48          -          -          -
                    Fast  985631026 3406265085 3728614892 2275699977
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0      69246    5331942
            Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process   13539896  812393760      23224    1393440
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process    1387770   73551810    4163782  249826920
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
Can anyone predict what may be causing these high number input errors and point me in the right direction? I can provide more information on the interface statistics and any other router related configuration if required.
Thanks.
13 Replies 13
Leo Laohoo
reliability 254/255
I think you got a cable issue.  This value should ALWAYS bee 255/255 and should never go down.
You have a point there regarding the cable and I will definitely look into replacing it, but....
Isn't Reliability value dropping an effect of the high number input errors and not a cause?
Reliability = total errors / total frames.
I got the below from a cisco support forum post -
"Reliability is generally used to identify whether we successfully transmit or receive a packet and it is expressed as a fraction of 255. It is calculated by summing all the packets received and transmitted and dividing that number into the sum of all input and ouput errors and expressing that as a fraction of 255. It is then exponentially weighted over five minutes so that the most current reading has greater weight than the first reading. Basic definition of reliability is errors/total frames. If your interface reads 255/255, then it means all is well."
Thanks.
Here's an output of show controller for that particular interface, do you think it indicates an issue with the cable itself?
show controller fa3/0
Interface FastEthernet3/0
Hardware is AMD Am79c971
ADDR: C00B0968, FASTSEND: 6023D370, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 613
LADRF=0x0000 0x0100 0x2001 0x0002
CSR0  =0x00000072, CSR3  =0x00001044, CSR4  =0x00004B1D, CSR15 =0x00008180
CSR80 =0x00009900, CSR114=0x00000000, CRDA  =0x2E0C36E0, CXDA  =0x2E0C3E10
BCR9 =0x00000001 (full-duplex)
CSR5  =0x00000001, CSR7  =0x00000820, CSR100=0x0000F000, CSR125=0x00005C3C
BCR2  =0x00000000, BCR9  =0x00000001, BCR18 =0x000019E0, BCR22 =0x0000FF06
BCR25 =0x000000FF, BCR26 =0x00000080, BCR27 =0x00000010, BCR32 =0x00004480
HW filtering information:
  Promiscuous Mode Enabled, PHY Addr Enabled, Broadcast Addr Enabled
  PHY Addr=0013.7F72.6001, Multicast Filter=0x0000 0x0100 0x2001 0x0002
amdp2_instance=0x70285F70, registers=0x4C100000, ib=0x2D75B9C0
rx ring entries=64, tx ring entries=128
rxring=0x2E0C3540, rxr shadow=0x66CA4F50, rx_head=26, rx_tail=0
txring=0x2E0C3980, txr shadow=0xC00B1760, tx_head=73, tx_tail=73, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
  0x00:  0  ffff.ffff.ffff  0000.0000.0000  13524414
  0x0F:  0  0000.0c07.ac03  0000.0000.0000 1313180569
  0x5C:  0  0100.5e00.0002  0000.0000.0000  43124342
  0x7E:  0  0013.7f72.6001  0000.0000.0000 389537278
  0xC0:  0  0180.c200.0002  0000.0000.0000         0
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000   1387845
  0xC5:  0  0180.c200.0007  0000.0000.0000         0
spurious_idon=0, filtered_pak=31187921, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=1, need_af_check=1
tx_limited=0(64)
PHY registers:
  Register 0x00:   2100  780D  7810  0003  0101  0000  0000  0000
  Register 0x08:   0000  0000  0000  0000  0000  0000  0000  0000
  Register 0x10:   0000  0000  4000  0000  38C8  0010  0000  0002
  Register 0x18:   0001  0000  0000  0000  0000
Thanks.
dhananjay95929,
I am having the same problem with a number of 2901 routers. Did you manage to resolve the issue in the end? Any solutions please suggest.
No.  Reliability is saying "How reliable is my layer 1".
Change the entire length of the cable OR run a full TDR test.
Replaced the cable and still see the incrementing errors.
Post the same commands as before, plus include "sh counter interface Fast 3/0".
sh int Fa3/0
  Internet address is x.x.x.x/24
     reliability 253/255, txload 2/255, rxload 18/255
  Last clearing of "show interface" counters 06:54:37
  Input queue: 0/2048/0/0 (size/max/drops/flushes); Total output drops: 1534
  30 second input rate 7211000 bits/sec, 1435 packets/sec
  30 second output rate 821000 bits/sec, 889 packets/sec
     31915418 packets input, 2934180951 bytes
     Received 37501 broadcasts, 0 runts, 0 giants, 0 throttles
     222060 input errors, 0 CRC, 0 frame, 222060 overrun, 0 ignored
     0 watchdog
     21232362 packets output, 2579907005 bytes, 0 underruns
sh controller fa3/0
CSR80 =0x00009900, CSR114=0x00000000, CRDA  =0x2E0C3570, CXDA  =0x2E0C3BE0
rxring=0x2E0C3540, rxr shadow=0x66CA4F50, rx_head=3, rx_tail=0
txring=0x2E0C3980, txr shadow=0xC00B1760, tx_head=38, tx_tail=38, tx_count=0
  0x00:  0  ffff.ffff.ffff  0000.0000.0000    277131
  0x0F:  0  0000.0c07.ac03  0000.0000.0000 838686427
  0x5C:  0  0100.5e00.0002  0000.0000.0000    681009
  0x7E:  0  0013.7f72.6001  0000.0000.0000  10086656
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000     21918
spurious_idon=0, filtered_pak=33483715, throttled=0, enabled=0, disabled=0
tx_underrun_err=1, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_limited=0(64)
PHY registers:
                   Other        302      16006        907      54420
                      IP    8997487 2398365672    6249085  949233080
                 DEC MOP          0          0         15       1155
                     ARP       3981     238860          1         60
          Throttle count          0
                   Drops         RP        123         SP          0
             SPD Flushes       Fast         74        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs   61174368      Drops          0
    Protocol  IP
                 Process  827218827 2329207405 1136910030 2216013801
                    Fast  508035336   28232545 1619944066 3467603049
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0      74403    5729031
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process   14838705  890322300      24881    1492860
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process    1491007   79023371    4473800  268428000
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
sh int fa3/0 stats
FastEthernet3/0
               Processor     302885   25285101     411720   55758990
             Route cache    9293267 2909400397    6183285  924543723
                   Total    9596152 2934685498    6595005  980302713
sh int fa3/0 summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* FastEthernet3/0          0     0    0   136 7578000  1438 739000  867    0
Nope.  Still faulty cable.
Ok, I failed over to the secondary router and made it the primary now. Replaced the cable 3 times. Moved the other end of the cable from the CAT 4500 switch number 1 to CAT 4500 switch number 2 on a different blade. Changed both ends of the connection (CAT and router) speed and duplex to auto / auto. There are no errors on the CAT switch end. The IOS on the routers is 12.4(15)T1.
Still see the same input errors. As you said though the reliabilty is 255/255 now.
sh int fa3/0
  Hardware is AmdFE, address is x.x.x (bia x:x:x)
     reliability 255/255, txload 1/255, rxload 15/255
  Last clearing of "show interface" counters 12:16:43
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 446
  5 minute input rate 6215000 bits/sec, 1163 packets/sec
  5 minute output rate 647000 bits/sec, 759 packets/sec
     64960035 packets input, 302868023 bytes
     Received 65287 broadcasts, 0 runts, 0 giants, 0 throttles
    20316 input errors, 0 CRC, 0 frame, 20316 overrun, 0 ignored
     0 watchdog
     40228479 packets output, 4289802996 bytes, 0 underruns
sh controller fa3/0
ADDR: 66F34824, FASTSEND: 6023D370, MCI_INDEX: 0
CSR80 =0x00009900, CSR114=0x00000000, CRDA  =0x2E0C3740, CXDA  =0x2E0C3D50
BCR9 =0x00000001
  PHY Addr=001D.7038.6421, Multicast Filter=0x0000 0x0100 0x2001 0x0002
amdp2_instance=0x66F358CC, registers=0x4C100000, ib=0x2D75B9C0
rxring=0x2E0C3540, rxr shadow=0x66F35EB8, rx_head=32, rx_tail=0
txring=0x2E0C3980, txr shadow=0x66F35FEC, tx_head=61, tx_tail=61, tx_count=0
  0x00:  0  ffff.ffff.ffff  0000.0000.0000     18312
  0x0F:  0  0000.0c07.ac03  0000.0000.0000  65147725
  0x51:  0  001d.7038.6421  0000.0000.0000    459815
  0x5C:  0  0100.5e00.0002  0000.0000.0000     46458
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000      1494
spurious_idon=0, filtered_pak=35497, throttled=0, enabled=0, disabled=0
tx_limited=0(64)
PHY registers:
  Register 0x00:   1000  782D  7810  0003  01E1  CDE1  000B  0000
I am also investigating buffer issues because I am seeing a lot of misses. Here's the output.
show buffers
Buffer elements:
     1115 in free list (1119 max allowed)
     60723871 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 148, permanent 50, peak 240 @ 07:14:29):
     112 in free list (20 min, 150 max allowed)
     43720721 hits, 11417 misses, 4403 trims, 4501 created
     4638 failures (0 no memory)
Middle buffers, 600 bytes (total 27, permanent 25, peak 97 @ 2w0d):
     25 in free list (10 min, 150 max allowed)
     22696413 hits, 4115 misses, 2035 trims, 2037 created
     3099 failures (0 no memory)
Big buffers, 1536 bytes (total 53, permanent 50, peak 53 @ 2w0d):
     52 in free list (5 min, 150 max allowed)
     20854107 hits, 2970 misses, 1235 trims, 1238 created
     2462 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 4, permanent 10, peak 203 @ 1d22h):
     3 in free list (0 min, 100 max allowed)
     43437529 hits, 2446 misses, 744 trims, 738 created
     2094 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 3 @ 1w1d):
     1 in free list (0 min, 10 max allowed)
     42 hits, 2052 misses, 150 trims, 151 created
     2052 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 3 @ 1w1d):
     1 in free list (0 min, 4 max allowed)
     42 hits, 2010 misses, 150 trims, 151 created
     2010 failures (0 no memory)
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 150, permanent 150):
     118 in free list (150 min, 150 max allowed)
     39086 hits, 0 misses
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 fallbacks
IPC buffers, 4096 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     63835 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 4 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
     4 hits in cache, 0 misses in cache
CRYPTO_HW buffers, 1548 bytes (total 1536, permanent 1536):
     0 in free list (0 min, 1536 max allowed)
     1536 hits, 0 misses
     1536 max cache size, 1024 in cache
     512 hits in cache, 0 misses in cache
Normal buffers, 1676 bytes (total 3840, permanent 3840):
     3840 in free list (128 min, 4096 max allowed)
     676 hits, 0 misses, 0 trims, 0 created
Private particle pools:
IDS SM buffers, 240 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     128 hits, 0 fallbacks
     128 max cache size, 128 in cache
     0 hits in cache, 0 misses in cache
AIM-VPN/HPII-PLUS buffers, 544 bytes (total 768, permanent 768):
     0 in free list (0 min, 768 max allowed)
     768 hits, 676 fallbacks
     768 max cache size, 256 in cache
     219478220 hits in cache, 676 misses in cache
FastEthernet3/0 buffers, 1548 bytes (total 192, permanent 192):
     0 in free list (0 min, 192 max allowed)
     192 hits, 0 fallbacks
     192 max cache size, 128 in cache
     95580571 hits in cache, 0 misses in cache
FastEthernet3/1 buffers, 1548 bytes (total 192, permanent 192):
     3235854 hits in cache, 0 misses in cache
FastEthernet4/0 buffers, 1548 bytes (total 192, permanent 192):
     5678829 hits in cache, 0 misses in cache
FastEthernet4/1 buffers, 1548 bytes (total 192, permanent 192):
     10353498 hits in cache, 0 misses in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 768, permanent 768):
     768 hits, 0 fallbacks
     768 max cache size, 512 in cache
     64302736 hits in cache, 0 misses in cache
     14 buffer threshold, 0 threshold transitions
GigabitEthernet0/1 buffers, 1664 bytes (total 768, permanent 768):
     1790387 hits in cache, 0 misses in cache
Actually that is not due to faulty cabling.
Router counts overruns as errors, even if they are valid packets on the wire.
And any error decreases reliability
paolo bevilacqua
Update IOS.
