Input and CRC errors but no controller errors?
cventici
Community Member
I am working on an issue where I see errors on the interface...
Serial0/1/1:0 is up, line protocol is up
  Hardware is GT96K Serial
  Description: Connection to TP Provider
  MTU 1500 bytes, BW 1984 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 122/255, rxload 118/255
  Encapsulation PPP, LCP Open, multilink Open
  Link is a member of Multilink bundle Multilink1, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w0d
  Queueing strategy: weighted fair  [suspended, using FIFO]
  FIFO output queue 0/40, 0 drops
  5 minute input rate 923000 bits/sec, 229 packets/sec
  5 minute output rate 955000 bits/sec, 173 packets/sec
     7324391 packets input, 3315314073 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     26446 input errors, 14140 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
But no errors are present on the controller...
Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Could this be a problem with the multi-link config?
Thanks!
Hello Cventici,
>> 20610 lost fragments, 3927978 reordered
    15227/8902947 discarded fragments/bytes, 0 lost received
    0x3D1F6D received sequence, 0xC032F9 sent sequence
as you can see there are 20610 lost fragments and 15227 discarded fragments and this is roughly similar to physical interface error counters
Hope to help
Giuseppe
Giuseppe Larosa
Hello Cventici,
you can use show ppp multilink to check ML PPP errors
Hope to help
Giuseppe
rtr03>sh ppp multilink
Multilink1
  Bundle name: xxxxxxxx
  Remote Endpoint Discriminator: [4] xxxxxxxx
  Local Endpoint Discriminator: [1] xxxxxxxx
  Bundle up for 1w5d, total bandwidth 3968, load 1/255
  Receive buffer limit 24000 bytes, frag timeout 1000 ms
    0/0 fragments/bytes in reassembly list
  Member links: 2 active, 0 inactive (max not set, min 1)
    Se0/1/0:0, since 1w5d
    Se0/1/1:0, since 1w5d
No inactive multilink interfaces
rtr03>
Hello Cventici,
Hope to help
Giuseppe
Thank you for pointing that out, I have opened up a ticket with our provider to review our multi-link config.
Have a good day!
