Input errors on fastethernet interface router 2811
dombsamuel
Community Member
First thanks for your time.
I have this output from show interfaces command for the fastethernet interface on a 2811 router.
Can any one help me find the causes of the crc and the ignored input errors on the interface?
The interface  configuration is:
interface FastEthernet0/0
description VLANS_CHILE
no ip address
ip route-cache flow
duplex full
speed 100
And it's pluged to gigabit interface on a 3560 switch witth version 12.2(25r)SEE4
The interface has subinterfaces. As an aexample:
interface FastEthernet0/0.1
description Vlan Marketing  & Directorio $FW_INSIDE$
encapsulation dot1Q 20
ip address 192.168.20.19 255.255.255.0
ip helper-address 192.168.23.100
ip nbar protocol-discovery
ip flow ingress
ipx encapsulation NOVELL-ETHER
ipx network 21
ipx type-20-propagation
standby 20 ip 192.168.20.1
standby 20 priority 130
standby 20 preempt
Here is the configuration of the interface on the switch:
interface GigabitEthernet0/40
description Hacia GW2_XCL
switchport trunk allowed vlan 1,20-27
switchport mode trunk
speed 100
duplex full
Thanks in advance.
Regards.
Samuel.
The output from the router's interface:
GW2_XCL#sh int fas 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001b.d4be.66e8 (bia 001b.d4be.66e8)
Description: VLANS_CHILE
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 99/255, rxload 99/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:34:53
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 38975000 bits/sec, 4344 packets/sec
5 minute output rate 38959000 bits/sec, 4340 packets/sec
     43681411 packets input, 1886473 bytes
     Received 157807 broadcasts, 8 runts, 0 giants, 0 throttles
     104 input errors, 54 CRC, 0 frame, 0 overrun, 42 ignored
    0 watchdog
     43695253 packets output, 4277351296 bytes, 0 underruns
     0 lost carrier, 0 no carrier
6 Replies 6
Edison Ortiz
Have you tried swapping the cables?
If so, try connecting the router to another interface in the switch - it could be a bad port at either end.
Thanks, for your answer.
Yes I have changed cables, with the same results.
I will change to another port on the switch, later this evening (people are working now). I haven't tried that yet.
Question:
If the problem is something phisical on the router's interface, why I don't have errors on the other side, on the switch interface?, It's that normal?
Thanks.
Regards.
Samuel.
Hey Samuel,
CRCs are considered input errors, and usually point to an issue with the other side of the physical connection. So, to answer your question it's normal to see CRCs on only one side of a link. That's most likely why Edison suggested you try connecting to a different switch port.
If you are going to change switch ports, I would suggest making sure you are moving to a different ASIC as well. To determine port / ASIC mappings, you can do a 'show platform pm if-numbers'.
Also, have you tried using auto-negotiated speed and duplex on this links? Since they're hardcoded you shouldn't see a mismatch, but just something to try..
Hope this helps!
1.  Remove the "speed 100" from your switch.  Instead try "speed auto 10 100".
2.  Remove the speed 100 from your router.
3.  On your switch, try the following:
Command:  test cable tdr interface ;
Wait for about 5 to 7 seconds;
Command:  sh cable tdr interface ; and
Post the output
Here is the output:
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/40    100M  Pair A     2    +/- 4  meters Pair A      Normal
                Pair B     2    +/- 4  meters Pair B      Normal
                Pair C     2    +/- 4  meters Pair C      Short
                Pair D     2    +/- 4  meters Pair D      Short
I change the cable, with identical result.
I also set speed auto in both sides as you say.
Thanks.
It is normal to have pairs C and D in shoert?
I have changed cables with identical result, each time.
Thanks.
