Interface direct connected Null0
Ken Lee
Level 2
Level 2
Hi All,
I have 2 Core Switches. The static route for 172.21.124.236 is configured at Core switch 1 because firewall is connected at this core switch 1.
Currently, am not sure why eigrp cannot push this route to Core Switch 1. Any ideas?
RG002#sh ip route 172.21.124.236
Routing entry for 172.21.124.0/22
  Known via "eigrp 2", distance 5, metric 3328, type internal
  Redistributing via eigrp 4, eigrp 2
  Advertised by eigrp 4
  Routing Descriptor Blocks:
  * directly connected, via Null0
      Route metric is 3328, traffic share count is 1
      Total delay is 30 microseconds, minimum bandwidth is 1000000 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
KA
7 Replies 7
  Please post the output of "show ip route 172.21.124.236 255.255.255.255".  Did you have "ip summary-address eigrp" applied on core1?  Please post the configuraion,excluding sensitive information.
HTH,
Toshi
Router001#
sh ip route 172.2.124.236
Routing entry for 172.2.124.0/24
  Known via "eigrp 4", distance 170, metric 28416, type external
  Advertised by eigrp 2
  Last update from 146.122.254.14 on GigabitEthernet0/1/0, 7w0d ago
  * 146.122.252.14, from 146.122.254.14, 7w0d ago, via GigabitEthernet0/1/0
      Route metric is 28416, traffic share count is 1
      Total delay is 110 microseconds, minimum bandwidth is 100000 Kbit
      Loading 1/255, Hops 1
Router002#sh ip route 172.2.124.236
Routing entry for 172.2.124.0/22
      Loading 1/255, Hops 0
RC001
interface GigabitEthernet0/0/0
ip address 172.1.3.1 255.255.255.248
no ip redirects
no ip proxy-arp
ip wccp web-cache redirect out
ip wccp 90 redirect out
ip flow ingress
ip summary-address eigrp 2 146.120.0.0 255.248.0.0 5
ip summary-address eigrp 2 172.2.124.0 255.255.252.0 5
ip summary-address eigrp 2 172.2.128.0 255.255.240.0 5
negotiation auto
cdp enable
service-policy input INBOUND
service-policy output OUTBOUND
interface GigabitEthernet0/0/1
ip address 146.122.254.1 255.255.255.252
no ip redirects
no ip proxy-arp
ip flow ingress
no negotiation auto
cdp enable
service-policy output WAN
router eigrp 4
network 146.120.0.0 0.7.255.255
redistribute eigrp 2
passive-interface default
no passive-interface GigabitEthernet0/0/0
no passive-interface GigabitEthernet0/0/1
no passive-interface GigabitEthernet0/0/2
no passive-interface GigabitEthernet0/0/3
no passive-interface GigabitEthernet0/1/0
no passive-interface GigabitEthernet0/2/0
router eigrp 2
distribute-list prefix DRN_Update out GigabitEthernet0/0/0
distribute-list prefix GRN_Update in GigabitEthernet0/0/0
default-metric 10000 100 255 1 1500
network 172.1.0.0
redistribute eigrp 4
distance 170 172.1.1.52 0.0.0.3 90
Router001#
Router002#
ip address 172.1.3.18 255.255.255.248
no ip redirects
no ip proxy-arp
negotiation auto
cdp enable
  ip address 146.121.254.1 255.255.255.252
no ip redirects
no ip proxy-arp
no negotiation auto
cdp enable
router eigrp 4
router eigrp 2
network 172.1.0.0
Router002#
Sorry Thotsaphon,
I just replied the config. anyway for more info, the core switch 1 connecting to Router 001and core switch 2 connecting to Router 002. And the route should be 172.2.124.236 which not able to go back to Core switch 1 .
I need to throw to Core Switch1 as it is connecting to this network range. The core switch 1 only have this static route. But I am not sure why it is not able to route to Core Switch 1 , instead it stuck at Router 002 . For your info, Router 001 and Router 002 they are interconnect and routes are sent across to each other.
Let me know if oyu need more info.
Thnaks,
KA
Hi Kent,
I feel the problem with summarization at EIGRP which by default suppresses the component routes.
Can you please try to utilize "leak-map" feature in "ip summary-address eigrp" command to advertise specifically
172.2.124.0/24?
Please check the following lab note for an example how leak map works...
http://www.networkers-google.com/nwgoogle/Routing/EIGRP/All%20about%20EIGRP%20Route%20Sum1305799297.html
Regards...
-Ashok.
With best regards...
Ashok
Thanks. I will check it this through.
Btw,
What about removing the below at core router 1?
Router001#
no ip redirects
no ip proxy-arp
ip flow ingress
What is the impact of doing this?
Anyone can help me?
Hi Ken,
    Please post a diagram,including ip address scheme. Please explain about your question in detail. You're using 2 eigrp processes on the router. I just want to know the detailed information and exact problems to solve your question.
Toshi
