Interface down/down on router interface
HW05194
Frequent Visitor
Frequent Visitor
Hi everyone,
I am trying to set up an eigrp lab on EVE-NG but on one router every time I set up the interface and no shut it I get the following messages:
*Apr 26 02:14:34.500: %LINK-5-CHANGED: Interface Ethernet0/0, changed state to administratively down
R8(config-if)#
*Apr 26 02:14:37.013: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Apr 26 02:14:38.013: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
R8(config-if)#
*Apr 26 02:14:47.017: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to down
*Apr 26 02:14:48.017: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to down
This is my configuration:
R8#show run int e0/0
Building configuration...
Current configuration : 79 bytes
interface Ethernet0/0
ip address 10.10.10.8 255.255.255.0
duplex auto
end
R8#show interface e0/0
Ethernet0/0 is down, line protocol is down
Hardware is AmdP2, address is aabb.cc00.0800 (bia aabb.cc00.0800)
Internet address is 10.10.10.8/24
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto Speed, media type is unknown media type
input flow-control is off, output flow-control is unsupported
Last input 00:02:03, output 00:02:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 packets input, 364 bytes, 0 no buffer
Received 1 broadcasts (0 IP multicasts)
29 packets output, 7675 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Whenever I no shut the interface, I am able to ping myself for like 5 seconds then the interface goes down again. Not sure how to go about fixing this issue any help would be greatly appreciated.
Try rebooting the device. Sometimes those virtualized instances are glitchy. If that does not work delete R8 and replace it with a new Router in the EVE-NG lab
Hope that helps
-David
5 Replies 5
Hope that helps
-David
Hi David,
Thanks for getting back to me I actually already wiped the router and was experiencing the same issues, so I replaced it with a new router (same version though) and was still experiencing the same issue. I will try that again and maybe switch to a different version of the router and will let you know if that works.
Thanks again,
Al-Hussein
Ok. If that doesn't work save configurations and restart the EVE-NG server. I don't see anything in the config that would make it shut down unless you didn't have an active link connecting that interface to another device.
Ok, perfect If it doesn't work, I will definitely try that. And yes, I do have a device connecting to this device with an active link. I should have mentioned that 🙂
HW05194
Frequent Visitor
Frequent Visitor
Switching to a Cisco vIOS router worked for me thanks again for your help David!
