IOS command reference
haris.cisco
Level 2
Level 2
is there any command to check what are the services running on a router by default
like
proxy arp
tcp small services
udp small services
ip finger
etc...
if there is pls let me know
thanks in advance
5 Replies 5
kamlesh.sharma
Level 5
Level 5
proxy arp u can check on show ip interface command.
tcp and udp small services are by default on in router
ip finger is also on
By default the UPD servers for Echo, Discard, and Chargen services are disabled.
thanks for the reply
it helps
but i want to know is there any tool which can specify what services are enabled by default for a specific IOS on a router
i think for that you have to read the ios guide ...
You can use a free port scanner to see what is open.
