IP CEF
xbaha12345
Level 2
Level 2
hello
I am trying to debug why my load balancing is not giving me a 100% of the bandwidth, i tried few commands, if some one please explain what they mean and if there is something wrong in their output:
Router#sh cef not-cef
CEF Packets passed on to next switching layer
Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag
RP 1231 0 3687843 13 290906 0 0 0
Router#sh cef drop
CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 7308 0 0 6 0 0
#sh ip cef receive
Apr 21 00:57:54.663: CEF-Receive: Packet for 65.55.251.108 -- unsupported featur
e
Apr 21 00:57:54.663: CEF-Receive: Not supported for 208.98.1.46 thru Dialer5 - r
eceive
Apr 21 00:57:54.663: CEF-Receive: Packet for 208.98.1.46 -- unsupported feature
eceive
Apr 21 00:57:54.663: CEF-Receive: Not supported for 209.73.166.140 thru Dialer2
- receive
22 Replies 22
So why don't you try "no ip cef".
It's few hundreds of PPS after all, and the router should be able with that with fast-switching without a problem.
Hi Baha,
Your MTU and adjust-mss values are the recommended values, like Paolo said why don't you disable CEF and we shall see what happens then, according to the router performance sheet there is merely any performance difference between CEF and Fast Switching (your CPU might increase a little bit):
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
BR,
Mohammed Mahmoud.
Why not use virtual-template instead of the dialer interface.
could you post me a sample config on how to use a virtual template?
also, i tried removing #no ip cef
and will post results in 24 hours.
thanks.
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 0/35
encapsulation aal5mux ppp virtual-template 10
no dialer pool-member 1
interface ATM0/2/0
bandwidth 1088
no ip address
hold-queue 224 in
pvc DSL 0/35
no dialer pool-member 2
interface ATM0/3/0
bandwidth 1088
no ip address
logging event atm pvc state
hold-queue 224 in
pvc 0/35
no dialer pool-member 3
interface ATM3/0/0
bandwidth 1088
no ip address
hold-queue 224 in
pvc 0/35
no dialer pool-member 4
interface Virtual-Template10
ip address x.x.x.x x.x.x.x
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
IP nat outside
Note that the IP address should be configured on the Virtual-Template10 then only one default route pointing on the next-hop address.
Also currently no need for route-maps (IF all links belong to the same ISP)because the traffic received on the Giga interfaces will follow the default route, But if you need to only NAT specific local hosts use the route-map but note that no need to match on the outgoing interface the route-map can only match on the IP address and begin NAT it IF the destination the host trying to reach is reachable through the outside nat interface.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
Hello Mr Mounir,
isnt there supposed to be a user name / password in the virtual template to authenticate me?
also, i'll be using one IP address for all my four links, is that right?
ill be using the same ISP, so the route shouls look like:
#route 0.0.0.0 0.0.0.0 (NEXT_HOP_IP) ?
finally for natting, since i am using the same ISP as you said i wont be needing route_map any more.
but i will be natting my local IPs on the ip address of the Virtual-Template10 .
let me know very excited to implement this config!
thanks.
Hi Baha,
Point 1 (virtual template to authenticate):
It's optional but no needs for authentication because it's point to point link, but if you care all you need to do it under the virtual template only add ppp authentication pap or chap and specifiy the AAA group or use the default AAA PPP profile.
Point 2 (Link IP address):
yes only one IP will be assigned to the virtual template, because all ATM interface considered as one link which presented by the virtual template.
Point 3 (Routing):
Yes only one default route should be pointing to the next-hop
Point 4 (NAT):
Yes you do not have to use route-map any more the below lines will be enough:
NAT Config:
ip nat inside source list 1 interface virtual template 10 overload
access-list 1 permit 1.1.1.1
access-list 1 permit 1.1.1.5 and so on
Let me know if you have any problem with such config.
Please Rate helpful posts.
Best Regards,
Mounir Mohamed
hello Mounir,
i am trying as a test to configure a virtual template on 2 lines befor i do it on all the lines, just to make sure there is nothing wrong.
so i started without giving IP address:
ip address negotiated
ip nat outside
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username xx password x
ppp multilink
i will get an ip address soon, but this is only for test purpose, it seemed there was no connectivity, is this normal, shall i proceede?
here is the output of the debug ppp nego:
Apr 27 05:08:38.560: ppp437 LCP: Failed to negotiate with peer
Apr 27 05:08:38.560: ppp437 PPP: Sending Acct Event[Down] id[1AF]
Apr 27 05:08:38.560: ppp437 LCP: State is Closed
Apr 27 05:08:38.560: ppp437 PPP: Phase is DOWN
Apr 27 05:08:38.560: ppp437 PPP: Send Message[Disconnect]
Apr 27 05:08:39.488: ppp438 PPP: Send Message[Dynamic Bind Response]
Apr 27 05:08:39.488: ppp438 PPP: Using default call direction
Apr 27 05:08:39.488: ppp438 PPP: Treating connection as a dedicated line
Apr 27 05:08:39.488: ppp438 PPP: Session handle[530001BB] Session id[438]
Apr 27 05:08:39.488: ppp438 PPP: Phase is ESTABLISHING, Active Open
Apr 27 05:08:39.488: ppp438 LCP: O CONFREQ [Closed] id 1 len 36
Apr 27 05:08:39.488: ppp438 LCP: AuthProto PAP (0x0304C023)
Apr 27 05:08:39.488: ppp438 LCP: MagicNumber 0x1875BDC4 (0x05061875BDC4)
Apr 27 05:08:39.488: ppp438 LCP: MRRU 1524 (0x110405F4)
Apr 27 05:08:39.488: ppp438 LCP: EndpointDisc 1 KAMC_NahdiTabuk
Apr 27 05:08:39.488: ppp438 LCP: (0x1312014B414D435F4E61686469546162)
Apr 27 05:08:39.488: ppp438 LCP: (0x756B)
Apr 27 05:08:39.508: ppp438 LCP: I CONFREJ [REQsent] id 1 len 30
Apr 27 05:08:39.508: ppp438 LCP: AuthProto PAP (0x0304C023)
Apr 27 05:08:39.508: ppp438 LCP: MRRU 1524 (0x110405F4)
Apr 27 05:08:39.508: ppp438 LCP: EndpointDisc 1 KAMC_NahdiTabuk
Apr 27 05:08:39.508: ppp438 LCP: (0x1312014B414D435F4E61686469546162)
Apr 27 05:08:39.508: ppp438 LCP: (0x756B)
Apr 27 05:08:39.508: ppp438 LCP: O CONFREQ [REQsent] id 2 len 14
Apr 27 05:08:39.508: ppp438 LCP: MagicNumber 0x1875BDC4 (0x05061875BDC4)
