IP forwarding
remeshkt
Community Member
We have a cisco 1721 having one "FastEthernet 0" and one "Eth 0" interfaces; connecting a DSL line to our internal LAN.
FastEthernet 0 interface is connected to the DSL line via ADSL modem (Zyxel) which is configured as bridge mode.
Eth 0 is connected to our LAN.
The router is configured primarily for IPSec and internet access.
We are able to access internet site from our internal network however the incoming traffic from the internet to our internal LAN (say for a web server hosted in our LAN) access fails.
Please find the configuration on our router as shown below.
I would appreciate if you could help us in configuring for incoming traffic.
Thank you
Ramie
My present router sh run details are as follows :--
sh run
Building configuration...
Current configuration : 1942 bytes
version 12.3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
--More-- ip subnet-zero
no ip dhcp use vrf connected
ip cef
no ip ips deny-action ips-interface
no ftp-server write-enable
crypto isakmp policy 1
hash md5
authentication pre-share
lifetime 3600
crypto isakmp key b001 address 111.x.x.20
--More-- !
crypto ipsec transform-set VF_GPRS esp-des esp-md5-hmac
crypto ipsec df-bit clear
crypto map VF_B 10 ipsec-isakmp
set peer 111.x.x.20
set transform-set VF_GPRS
match address b_VF
interface Ethernet0
ip address 172.16.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
half-duplex
interface FastEthernet0
ip address 130.x.x..49 255.255.255.0 secondary
ip address 130.x.x..44 255.255.255.0
ip nat outside
speed auto
--More-- no cdp enable
crypto map VF_B
ip default-gateway 130.x.x..1
ip classless
ip route 0.0.0.0 0.0.0.0 130.x.x..1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
ip nat inside source static 172.16.0.6 130.x.x..49
ip access-list extended b_VF
permit ip 172.16.0.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip any any
ip access-list extended telnet
permit ip host 111.x.x.130 any
permit ip 172.16.0.0 0.0.0.255 any
deny ip any any
access-list 101 deny ip 172.16.0.0 0.0.0.255 192.168.0.0 0.0.0.255
--More-- access-list 101 permit ip 172.16.0.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
access-class telnet in
login local
end
11 Replies 11
nordick26
Level 4
Level 4
Hi Ramie,
does your Zyxel device perform any kind of NAT/PAT?
If yes, you would need to do some port mapping on it to your server address you are natting on your router.
If not, i guess 130.x.x..49 should be the public address of your server, right?
Is this (130.x.x..49) address known by ISP and reachable from internet?
You can make just a simple test if you would like and so to interchange the addresses:
ip address 130.x.x..44 255.255.255.0 secondary
ip nat inside source static 172.16.0.6 130.x.x..44
btw: is your server able to reach internet addresses?
Chceck if the the translation is correct using:
sh ip nat translations
Ivan
Ramie
I agree with Ivan that some clarification of the situation would be helpful. Would I be correct that the 130.x.x.49 is the address that the server is using? If so why is it defined as a secondary address on the router? The effect of this is that anything from outside that is directed to 130.x.x.49 will be sent to the router instead of being sent to the server.
My first suggestion is to remove the secondary address and see if the situation improves.
If that is not the case then can you tell us what address the server is using?
Rick
Rick
Hi Ivan,
Thanks for your prompt response.
Zyxel does not have any configurations exists,it's configured as bridged mode as an ethernet converter,converting RJ 11 DSL line to RJ 45.
yes,130.x.x.49 is the public IP of our server.
yes,130.x.x.49 address known by ISP and it is reachable from the internet.
I tried configuring the above mentioned
ip nat inside source static 172.16.0.6 130.x.x..44 configuration,IP forwarding went through fine but this configuration changes made IPSec stop functioning.
Yes,our internet server able to reach internet addresses.
Ramie
Ramie,
so in this case, have you tried to modify "set peer 130.x.x..44" on your IPsec peer router to "set peer 130.x.x..49"?
and "crypto isakmp key b001 address 130.x.x..49" as well.
If you says this is the only thing that doesn't work, this should correct it.
Ivan
[pls rate all helpful posts]
Ivan,
There is no "set peer 130.x.x..44" configured in the above mentioned sh run details.We are actually looking to configure IPforwarding (request comes from 130.x.x.49 has to be forwarded to 172.16.0.6 without bring down any other configurations(IPsec or Internet access)
Set peer is configured for a different static IP which is for IPSec "set peer 111.x.x..20".
Kindly Advice
Ramie
Ramie
I raised an issue about the configuration of the secondary address. Can you tell us whether the router configuration still has the secondary address configured?
Rick
Rick
Rick
I have removed the secondary address,still it is not working.
Ramie
Ramie
Thanks for the update. In this case perhaps an updated posting of the config would be helpful.
Rick
Rick
sh run
version 12.3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip cef
hash md5
lifetime 3600
--More-- !
set peer 111.x.x.20
match address b_VF
interface Ethernet0
ip nat inside
half-duplex
ip nat outside
speed auto
crypto map VF_B
ip classless
no ip http server
deny ip any any
deny ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login local
end
Rick,
Attached latest configuration details above.please advise.
Ramie
Ramie
I have looked at the config that you posted and I do not see a problem that would prevent access. Can you confirm that address that people from outside will use to try to get to the server and confirm that address that the server has on the inside of your network?
Rick
Rick
