Routing and SD-WAN
Labels
Welcome to the Cisco Community Ask Me Anything EventWe invite you to participate in our upcoming Ask Me Anything (AMA) conversation. Please submit your questions from Thursday, September 3, 2026, through Wednesday, September 30, 2026. Our experts Eri...
Hello Guys,We are planning to upgrade Cisco router Cisco C8300-1N1S-4T2X from XE image 17.6.5 (Rommon image 17.3(5r)) to latest XE image 17.9.5a. As per Rommon compatibility matrix, this new XE image should have minimum rommon image of 17.3(1r) and m...
Noovi by • Level 4
  • 9199 Views
  • 13 replies
Not sure how or if this is possible, so thought I’d ask the combined brains on this board before I waste my time trying something that ain't gonna work I have an MX on a site with WAN1 connected to an ISP router.MX IP is 192.168.1.2ISP router (MX gat...
dunky by • Level 9
  • 150 Views
  • 3 replies
This is a pretty niche issue but figured I'd flag it here in case it's applicable to anyone else looking to upgrade.Starting in MX 26.1, if a VLAN uses Proxy to upstream DNS for DHCP DNS nameservers and has a group policy is applied, the group policy...
Brash by • Meraki Community All-Star
  • 248 Views
  • 6 replies
  • 3 Helpful votes
Just wondering if anyone had done any testing with HTTPS inspection on MX? Interested in knowing how it impacted performance as well as any other gotcha's.https://documentation.meraki.com/SASE_and_SD-WAN/MX/Operate_and_Maintain/Content_Filtering_and_...
I avoided using the word redistribute and used the word "inject" on purpose. I was able to do this using the network command instead of the "redistribute static" command. I tested using RIP version 2 and EIGRP named mode. I didn't try EIGRP classic, ...
Hi , Anyone here running MX 19.2.9 ? If so can you check the firmware version with the API ? ( getOrganizationDevices )100% of my networks migrated are showing :  "firmware": "Not running configured version", "url": "xxxxx", "details": [ { "name": "R...
Raphael_L by • Meraki Community All-Star
  • 156 Views
  • 2 replies
Recently, an interviewer asks me some questions which I would like to share and would like your thoughts about it:1). What is Internal and External Vlan?? I've heard only standard and extended vlan.2). Why we need two BGP's: iBgp and eBgp, why don't ...
