MX67 Interconnectivity Issues
DKetchum
Community Member
We set up a MX67. It can ping and connect back to the HQ office but if we run an application hosted at the HQ then it will lag out.
16 Replies 16
DKetchum
Community Member
Spoke(MX67) firmware version 18.107.2
HQ(MX100) firmware version 18.107.5
As far as the speeds, I asked earlier how do I view the speeds? Are you requesting I run a speed test while being directly connected?
CMR
Meraki Community All-Star
When you order a WAN service then you should be told the speed, if you cannot get this information then yes, a speedtest from a local client when it is quiet would give you a good idea. Do you know what kind of services they are - fibre leased line, VDSL (part fibre broadband), dial up modem etc.?
If my answer solves your problem please click Accept as Solution so others can benefit from it.
