OSPF Routing Problem
1lumkk
Level 2
Level 2
My R3 acts as a frame-relay switch connecting R1. The frame-relay circuit is up. However, R1 is unable to see R6 thru ospf routing. Attached here is the config & diagram to explain. Hope some1 can help this novice. Many thanks.
17 Replies 17
The diagram is a little confusing. Red is the serial link and there is a partially obscured black line representing FE between R2 and R3.
I think we might benefit from seeing the running config on R2.
Hello Stuey,
yes it is the FE link between R3 and R2 that needs to be part of area 0; otherwise area 3 has no connection to backbone area.
The correct note is that of Narayan.
A router can be a FR switch on some interfaces and can take part to OSPF routing on other interfaces so the config appears correct.
The only problem is that area 3 is not attached to area 0.
I agree the diagram is a little misleading.
Hope to help
Giuseppe
p.s. what about your BSCI exam ? I hope you did well
Mohamed Sobair
Level 11
Level 11
NO, Its not confusing..
Its very clear, He told verbally that R3 acts as frame-relay Switch, besides relative config are also wrong.
Mohamed
