PBR Issue
vlad.vlaicu
Community Member
Hi guys!
I am practicing some route-maps and I came across an issue I don't quite get. Please see the below topology
My intention is to create a policy on Aggie so that when I have to route a packet destined to 192.168.13.1 to go right to Ace because with the current configuration, Aggies reaches 192.168.13.1 via Abu.
This is my configuration on Aggie:
interface FastEthernet0/0
ip address 192.168.23.2 255.255.255.0
ip policy route-map TO131
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.12.2 255.255.255.0
duplex auto
speed auto
access-list 100 permit ip host 192.168.23.2 host 192.168.13.1
route-map TO131 permit 10
match ip address 100
set ip next-hop 192.168.12.1
The issue is that although after my logic Aggie should reach 13.1 directly via Ace, is still goes through Abu. What am I missing? Please let me know you require additional topological configuration.
cadet alain
PBR config must be applied on the interface receiving the traffic inbound if that traffic is forwarded or in global config for packets coming from the router itself. So in your case it should be configured in global configuration mode and not on the interface  like this: ip local policy route-map TO131
Regards.
Alain.
cadet alain
Regards.
Alain.
That helped a lot. Thank you!
