Problem NAT inside
z.elguesmi
Community Member
a have a router CISCO 1841 and I configured a NAT inside from the router to the firewall like this :
ip nat inside source static firewall_adresse  public_adresse and its work fine and when a added it I do this command "wr" to save the configuration and I restarted the router many times and it still work fine
but in the last five months this NAT does not exsit twice and I must add it a gain
can you help please or explain why happened this
thx
3 Accepted Solutions
Rahul Kukreja
Level 4
Level 4
This look like a software issue. Check if your IOS is hitting the following software defect -
CSCsi30964
Static NAT statement disappears from running-configuration
tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsi30964
Also please post the output of show run, sh ver and which NAT statement observed issue.
Please rate the helpful posts.
Here are the bug details -
Symptoms:
On a Cisco router performing NAT, static NAT statements may disappear from the running-configuration during operation. Any new flows requiring translation via the missing statement may fail.
Conditions:
- This problem was first experienced in IOS 12.4(9)T.
- It has only been reported for extendable, inside source static NAT statements
for TCP ports 80 (HTTP) and 25 (SMTP), with and without a route-map:
Examples:
ip nat inside source static tcp x.x.x.x 25 y.y.y.y 25 extendable
ip nat inside source static tcp x.x.x.x 25 y.y.y.y 25 extendable route-map nonat
ip nat inside source static tcp x.x.x.x 80 y.y.y.y 80 route-map nonat extendable
- After the statement disappears from the running-configuration, it is still
visible in the startup-configuration.
- Existing translations created before the disappearance are cached in the NAT
translation table and continue to work correctly.
Workaround:
Reload the router.
Could you confirm following : Was the NAT translation there in startup-config, once it was not seen in running-config ?
You are using 124-11.XJ4 IOS. I don't think the defect is resolved in this IOS.
In mainline train the defect is fixed from 12.4(18b) onwards.
Please check the Release notes and features in use available in the mainline release if you are planning for upgrade.
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
You have 128 Mb of DRAM on this router.
I'm not sure if I understand your question correctly..
Are you telling when the VPN traffic is going via this Router, then when you type show run it doesn't show you the output.
and when the VPN traffic is blocked, you are able to see the output.
If that is the case, you may need to check CPU & Memory Utilization, Interface counters on the Router when the issue is happeneing to determine the exact cause.
sh proc cpu sorted | ex 0.00
sh mem stat
sh interface
7 Replies 7
Rahul Kukreja
Level 4
Level 4
CSCsi30964
sorry for the delay and thanks for the response
sorry I  cant post the result of show run  my boss refused this but here is the exemple of nat
==>it  means  all the trafic came in the interface outside of the router will  be translated to the interface outside of the firewall
and the result of show version :
1841#show version
Cisco IOS Software, 1841 Software (C1841-BROADBAND-M), Version 12.4(11)XJ4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 13-Jul-07 21:24 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
mdinar uptime is 13 hours, 57 minutes
System returned to ROM by reload at 22:21:15 UTC Sun May 12 2013
System restarted at 22:22:09 UTC Sun May 12 2013
System image file is "flash:c1841-broadband-mz.124-11.XJ4.bin"
Processor board ID FHK13447469
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 ATM interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
and if possible haw can I desplay the total of memory (RAM) and if possible to add more RAM
thx
Symptoms:
Conditions:
Examples:
Workaround:
Reload the router.
thx for replay ,
for your question "
Could you confirm following : Was the NAT translation there in startup-config, once it was not seen in running-config ?"
==> I have not verified the start-up config i added directly the NAT but if it will be happened more time I will verify
If  I will upgrade ths IOS I will tell you if its good or not
another problem :
if there are many trafic the VPN is down and if I type the command " sh run" there is no information to desplay but when I block the PC whose generate the trafic the router work fine and i have a result for " sh run" and the VPN is UP
i would ask if this problem related to RAM ?
Thx for Help
sh mem stat
sh interface
in my question I mean :  when there are big trafic in the router the VPN dont work and when I type show run it doesn't show me the output but when I stop the source of this big trafic the vpn is UP and there is an output for the "sh run "
but  I think you answer for my question its a problem of CPU or Memory
thx for all
hello,
please you have any idea how can I configure QoS in the router CISCO1841 for the port IPSEC(UDP 500 ,UDP 4500) and the port tcp 4433
thx for your help
