Same BGP
majed.balsharaf
Level 3
Level 3
  I am having two circuits of BGP with same AS 65xx5.
Can i connect them in one router and split the traffic,
as i need
my LAN 1 to go via WAN 1
my LAN 2 to go via WAN 2
As I am having configuration for both WAN's
For WAN 1
router bgp 65xx5
nei 17
2 Accepted Solutions
Simon Brooks
Level 5
Level 5
Easiest option is policy base routing for dource of traffic pointing to each next hop neighbour respectively.
Sent from Cisco Technical Support Android App
The below will be fine, you can have as many connections to another AS (remote-as) as you wish, Your only challenge is how best to make use of the circuits.
neighbor 10.21.x.225 remote-as 65000
neighbor 172.31.x.221 remote-as 65000
Regards Neil
http://uk.linkedin.com/pub/neil-grant/20/5b0/267
Regards Neil http://uk.linkedin.com/pub/neil-grant/20/5b0/267
10 Replies 10
Simon Brooks
Level 5
Level 5
Are the uplinks to same isp?
Simon Brooks
Level 5
Level 5
Sorry by mistake I did the answer correct. Actually both are from same BGP and if i give the neighbor address the one exit will get over write.
So thats why I am confused.
Steven Clinton
Level 3
Level 3
How are you wanting to separate the traffic (inbound, outbound, by subnet), will Internet traffic be in involved?
     Thanks for the reply actually this circuits are IPVPN circuits with BGP.
neil grant
Level 3
Level 3
Outbound routemap
     Neighbough 1  Adverstise Lan 1 as primary
     match LAN 1
     set MED 100 (lowsest preferred)
     Match LAN 2
     Set Med 200
     Neighbough 2
     match LAN 1
     Set MED 200
     Match Lan 2
     Set Med 100
Inbound route map
Match disired Prefix
Set Weight or local preference
Your provider will probably (by default, and assuming you are only using the one provider)  support multipath (if not, probably worth asking)
Router bgp X
maximum-paths 2
This will load share per session across all prefixes.
Thanks I am near to my answer
But I have to interface WAN IP's
for LAN 1 WAN ip is
10.21.x.224/30
For LAN 2 WAN ip is
171.31.x.220/30
With Same bgp
if I assign the interface with this IP's ok. but when I go in router bgp 65xx5 what neighbour shall i choose
Example:
router bgp 65xx5
10.21.x.223 is of WAN 1
if I try to add WAN 2 neighbor
router bgp 65xx5
(this will overwrite my WAN 1 neighbor IP)
I am using 2951 router
neil grant
Level 3
Level 3
Route Map example:
route-map Set-Primary-Out permit 10
set metric 100
route-map Set-Primary-In permit 10
set local-preference 200
route-map Set-Secondary-Out permit 10
set metric 200
route-map Set-Secondary-In permit 10
set local-preference 100
for LAN 1 WAN ip is
10.21.x.224/30
For LAN 2 WAN ip is
171.31.x.220/30
With Same bgp
Example:
router bgp 65xx5
router bgp 65xx5
Regards Neil
