Serial interface problem
telkholy
Community Member
Dear all
I have a 1721 router with WIC-1T connected to framerelay network, when the modem is powered off and then powered on again serial interface becomes down/down and not becomes up again except i unplug & plug the serial cable connecting the modem and the router.
I changed everything; router, WIC-1T, serial cable & modem; and the problem still exist.
Anyone has any idea about that.
spremkumar
Level 11
Level 11
hi
can you revert back the exact ios code which you are running in this router ?
Since you have already changed the cable,card & modem may be the possible problem can be with the IOS code coz of some unknown/known bug.
regds
Find bellow the configuration on the router
The IOS image is c1700-y-mz.124-5a.bin
Building configuration...
Current configuration : 1295 bytes
! No configuration change since last restart
service password-encryption
logging queue-limit 100
ip subnet-zero
ip name-server X.X.X.X
isdn switch-type basic-net3
interface BRI0
ip address 1.1.1.1 255.255.255.252
encapsulation ppp
dialer idle-timeout 60
dialer string xxxxxxx
dialer load-threshold 1 either
dialer-group 1
no fair-queue
no cdp enable
ppp chap hostname xxx
ppp chap password 7 xxxxxxx
ppp multilink
interface FastEthernet0
ip address X.X.X.X 255.255.255.252
speed auto
interface Serial0
bandwidth 64
no ip address
no ip redirects
no ip unreachables
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
backup delay 5 60
backup interface BRI0
frame-relay interface-dlci 20
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X
no ip http server
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password 7 0518160A265E16031607
login
end
hi
Can you try add a new floating static route in place of those backup commands under the serial interface ?
just remove these command backup delay 5 60
backup interface BRI0 from the serial interface and try configuring ip route 0.0.0.0 0.0.0.0 bri0 10.
After doing this can you try the same exercise which you were doing earlier and check whether your serial port comes active (up/up) instead of down/down as mentioned in your earlier mail..
regds
Thank you first for your valueable recommendations
I did that before, i removed the configuration of BRI at all and i maintain the configuration of the serial only.
and the same problem exist.
