TCP session Timeout
kazatti
Community Member
There are times when communication becomes unstable.
We believe that there is a possibility of exhaustion of TCP sessions because there is only one public IP for IPv4.
When a similar problem occurs in Cisco ISR, there is an improvement by changing the TCP session timeout value, and I would like to know if it is possible to do the same with Meraki.
Rasmus Hoffmann Birkelund
Meraki Community All-Star
Nothing available to the user in the Dashboard. Perhaps in the backend. Have you tried opening a ticket with Meraki Support?
LinkedIn ::: https://blog.rhbirkelund.dk/
Like what you see? - Mark as helpful ## Did it answer your question? - Mark it as a Solution 🙂
All code examples are provided as is. Responsibility for Code execution is solely your own.
Philip D'Ath
Have you got an appropriately sized MX based on the number of users?
https://meraki.cisco.com/product-collateral/mx-sizing-guide/?file
If so - you won't be having a TCP session limit issue.
