WAN Network Simulator solution
kaoslife
Community Member
Hello, we are looking for a hardware/software solution that can simulate a WAN or two that would allow us to test our hardware setup/config before deploying it in the production environment.
I've looked at PacketStorm products and was wondering if anyone has tried this or any other solutions. We would like something that could do 3 or 4 sites and multiple WAN connections as well. Currently all connections to the WAN are IP based 10/100 Ethernet connections
Thanks in Advance
bjw
Level 8
Level 8
WAN, when I read WAN, I think serial interfaces, special purpose modules, what type of WAN connections are you talking about that use 10/100 Ethernet connections?
In a typical router we have Ethernet interfaces that point to ethernet network segments and serial/async/special purpose interfaces that connect to WAN technologies (Frame Relay, ATM, T-1/E-1 etc)
kaoslife
Community Member
Sorry for the confusuion about our network we are trying to simulate. Our primary network now consists of 6 sites that all have a router provided by the telco. These have a 10/100 ethernet connection that we connect to. Our backup network is a Connection to the local ISP provider and is also a 10/100 Ethernet connection. Maybe the subject should have been Network Simulator, rather than WAN.
bishwkum
UPDATE: now its  https://www.keysight.com/us/en/products/network-test/network-test-hardware/network-emulator-ii.html
https://www.insight.com/en_US/shop/product/946-0070/IXIA/946-0070/Ixia-Network-Emulator-II--network-emulation-device/
I have used IXIA (now insight) 5-6 years ago.  it has 10G SFP+ Module option and also RJ45 Module option (if i remember correctly). And  we had connected it via FEX . NX5K in out LAB.
