1:1 Static NAT for overlapping private IP space
judu
I would like to implement
1:1 static NAT. I am using ISR1100 IOS-XE
For background (in the attached image):
  • R2 is a third-party router (such as a customer or partner). It has a
    192.168.1.0/24 network
    It may or may not be connected to the internet (or other networks).
  • R1 is our router providing access to devices in the third-party
  • R1 is connected to
    R2's 192.168.1.0/24 network
    (through the network switch).
  • R1 has an
    IP 192.168.1.50
    but R2 remains the
    default gateway
  • A static route is added on R2 to route traffic to us on
    R1's 192.168.1.50
    interface.
  • R1 (our router) connects to a larger network
    (10.0.0.0/8)
    through VPN.
  • We can assume address space between instances of R2 (customer/partner router) overlap globally.
I can successfully ping both directions.
I will allocate a CIDR block to each R1 instance within the
10.0.0.0/8 network
such as
10.0.0.0/24
making them globally unique and routable.
Due to R2 (customer/partner router) address space not being globally unique, I would like to implement 1:1 static NAT on R1 (our router). There would be between 1 and 3 hosts NAT'd.
So if there were three hosts in
192.168.1.0/24
I would want to be able to access them using
10.0.0.0/8
addresses as follows:
  • 192.168.1.100 : 10.0.0.50
    (this address is flexible, can be within the
    10.0.0.0/24
    or a neighboring block)
  • 192.168.1.125 : 10.0.0.51
  • 192.168.1.126 : 10.0.0.52
I have tried the following to achieve
I marked the interface to R2 as ip nat outside and the interface the
host 10.0.0.100
was in to
ip nat
inside. From the router, I could
ping 10.0.0.50
after issuing this command, but I could not ping from the
 host 10.0.0.100 to 10.0.0.50.
ip nat
inside source static
192.168.1.100 10.0.0.50
I may put R1's interface to R2 in a separate VRF and use VASI. Still trying to figure out the best path forward. Here are two links I was reading through about NAT between two different VRF's in IOS-XE.
https://community.cisco.com/t5/security-knowledge-base/nat-with-vrf-ios-vs-ios-xe/ta-p/3156555
https://www.cisco.com/en/US/docs/ios/ios_xe/sec_data_plane/configuration/guide/sec_vasi_vrf_aware_software_infrastructure_ps9587_TSD_Products_Configuration_Guide_Chapter.html
I am thankful for any advice on how to achieve this 1:1 static NAT as described.
judu
I have gotten this working! The following article was extremely useful.
https://wax-trax.medium.com/understanding-and-configuring-network-address-translation-nat-for-cisco-ccna-ccnp-and-ccie-7fef92fa654c
Case 12: Overlapping IP subnets (twice NAT)
This use case is most frequently seen during network mergers. Using NAT so that devices with overlapping subnets can achieve bidirectional communications can be very confusing. In the real world, this should be seen as a temporary fix until permanent IP subnets can be reassigned. To demonstrate this, I kept all of the names the same but changed the Remote subnet to
10.1.1.0/24
so it overlaps with Local. Additionally, all static routes from LR and ISP1 have been removed, so no routing is configured anywhere yet.
The previously mentioned static nat definition remains in place (although modified to use the second NAT option in the image) performing a 1:1 mapping from
10.0.1.50 to 192.168.1.100
I will add additional 1:1 mappings as needed. I also tested out the network mapping, but I prefer the 1:1 for my use case. Both worked well.
ip nat outside source static 192.168.1.100 10.0.1.50 add-route
A second NAT is necessary to translate the inside. I am using a pool of addresses (it can be much smaller). I intentionally chose not to use PAT overloading as it is not necessary for my use case.
I found that you MUST use an extended
access-list
here. The standard does not work. I will restrict this later.
This will map
10.0.0.100 to 10.0.3.1
(for example) so it can be routed back to R1.
ip nat pool CUST 10.0.3.1 10.0.3.99 prefix-length 24
ip access-list extended NAT
 10 permit ip any any
ip nat inside source list NAT pool CUST
R2's static route will be changed to match the CUST nat pool:
ip route 10.0.3.0 255.255.255.0 192.168.1.50
6 Replies 6
judu
Update: I have made some progress.
By adding
add-route
to the static nat definition, traffic flows correctly from
10.0.0.100 to 192.168.1.100 using 10.0.0.20
ip nat outside source static 192.168.1.100 10.0.0.20 add-route
R1#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
--- ---                ---                10.0.0.20          192.168.1.100
icmp 10.0.0.100:20     10.0.0.100:20      10.0.0.20:20       192.168.1.100:20
tcp 10.0.0.100:53100   10.0.0.100:53100   10.0.0.20:22       192.168.1.100:22
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C        10.0.0.0/24 is directly connected, GigabitEthernet0/0
L        10.0.0.1/32 is directly connected, GigabitEthernet0/0
S        10.0.0.20/32 [1/0] via 192.168.1.100
C        10.20.20.0/24 is directly connected, GigabitEthernet0/2
L        10.20.20.1/32 is directly connected, GigabitEthernet0/2
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/1
L        192.168.1.50/32 is directly connected, GigabitEthernet0/1
Packet capture on wire from
Host-10.0.0.100 <-> R1-10.0.0.1
 Frame 1: 98 bytes on wire (784 bits), 98 bytes captured (784 bits)
 Ethernet II, Src: RealtekU_00:4c:31 (52:54:00:00:4c:31), Dst: RealtekU_1a:9b:b1 (52:54:00:1a:9b:b1)
 Internet Protocol Version 4, Src: 10.0.0.101, Dst: 10.0.0.20
 Internet Control Message Protocol
R1-192.168.1.50 <-> R2-192.168.1.1
 Ethernet II, Src: RealtekU_1c:2a:aa (52:54:00:1c:2a:aa), Dst: RealtekU_05:82:6c (52:54:00:05:82:6c)
 Internet Protocol Version 4, Src: 10.0.0.101, Dst: 192.168.1.100
The destination address has been translated from
10.0.0.20 to 192.168.1.100.
Now I just need to figure out how to translate the source address to enable other
10.0.0.0/8
networks to communicate over the NAT link. In this packet capture on wire from
Host-10.20.20.100 <-> R1-10.20.20.1, pinging 10.0.0.20.
 Frame 2: 98 bytes on wire (784 bits), 98 bytes captured (784 bits)
 Ethernet II, Src: RealtekU_0c:73:b9 (52:54:00:0c:73:b9), Dst: RealtekU_18:78:e5 (52:54:00:18:78:e5)
 Internet Protocol Version 4, Src: 10.20.20.100, Dst: 10.0.0.20
 R1-192.168.1.50 <-> R2-192.168.1.1, the source 10.20.20.100
needs to be translated in order for the reply packet to be routable back to R1.
 Frame 8: 98 bytes on wire (784 bits), 98 bytes captured (784 bits)
 Internet Protocol Version 4, Src: 10.20.20.100, Dst: 192.168.1.100
judu
10.1.1.0/24
access-list
This will map
Same link I share'
Glad your issue solved
Have a nice day
MHM
I appreciate your assistance, however these links are not the same.
it same but you missing this part I think.
IP NAT INSIDE and IP NAT OUTSIDE is trick here, you smart and faster than me, so you get solution in same time I share link.
what important here the issue is solved.
