1 router, 2 ISP's running BGP. How to prefer one received default route from ISP over the other?
pcweber
I have an ASR 1000. 2 ISP's and gettign partial routes from each. Also, gettign default routes from each. OF course the one I prefer is never the populated default route unless I shut the BGP session down to the other ISP. So this proves I am gettigna  Def route from both. I tried setting up a route map and applying it to the inbound BGP. Does not seem to change anything. Here is what I have for related config.
router bgp 15263
 no bgp transport path-mtu-discovery
 bgp log-neighbor-changes
 network 198.175.140.0
 network 198.175.141.0
 timers bgp 12 40
 neighbor 41.14.12.221 remote-as 3356
 neighbor 41.14.12.221 description **L3 BGP**
 neighbor 41.14.12.221 prefix-list prefixfilter#2 out
 neighbor 41.14.12.221 route-map PREPEND#2 out
 neighbor 169.40.253.129 remote-as 7029
 neighbor 169.40.253.129 description WINDSTREAM BGP PEER*****
 neighbor 169.40.253.129 soft-reconfiguration inbound
 neighbor 169.40.253.129 prefix-list prefixfilter#2 out
neighbor 169.40.253.129 route-map PREPEND#3 out
 neighbor 169.40.253.129 route-map from-WS in (this is the BGP neighbor I wish to have the default route be less preferred. And any revived routes for that matter)
Below is the route-map that is applied inbound. As you see I am trying to add metric, local pref, weight, and even AS prepends. Nothing seems to impact the inbound received Def route. Also, is there a way to affirm the received route details like you can with outbound bgp routes by using the "sh ip bgp nei x.x.x.x advertised routes?
route-map from-WS permit 10
set metric 99999
set local-preference 88888
set weight 777
set as-path prepend 7029 7029 7029 7029
Giuseppe Larosa
Hello @pcweber ,
but your route-map is doing the opposite rising weight and local preference !
all you need is to assign a less then 100 (default value)  local preference to received routes
The highest local pref is preferred
set local-preference 80
alternatively you can increase the weight on the other neighbor.
Hope to help
Giuseppe
6 Replies 6
Jon Marshall
The weight on it's own should be enough.
What does the output of "sh ip bgp" look like ?
Did you do a "clear ip bgp 169.40.253.129 soft in" after applying your route map.
Jon
Hello
Do the default have a assigned weight value already if so you may need to increase the weight value you have already applied to the route-map?
sh ip bgp | in 0.0.0.0
Kind Regards
Paul
on a side note, I assume you do not use all these values in the same route map ? The below should be sufficient:
set weight 777
route-map from-WS permit 20
This will ensure that routes from this neighbor (169.40.253.129) are preferred.
Giuseppe Larosa
Hello @pcweber ,
Hope to help
Giuseppe
Giuseppe
Good spot, I missed the bit about less preferred.
Jon
OK, my alerts to the forum posts is not working so I did not realize there were replies. The route- map below achieved the goal. The one I had was the result of incrementally adding things to see if I could get it to affect the received def. route. Thank you and this did it as I had the preference value backwards.
