1 Router 2 WAN links to 1 ISP with HSRP
Mundo
Hello Everyone,
I am having some difficulties with the following.
I have 2 WAN ports to the same ISP where I need to configure these two ports as Primary and Backup with HSRP.
Each interface has its own /30 subnet.
Now I am comfortable with LAN side of things but this has me struggling for couple of hours and its evading me since I know I need at least 4 usable IPs to configure the HSRP, but the 2 WAN ports are the thing that is throwing me off.
interface GigabitEthernet0/0/1.1
description WAN_Main
bandwidth 50000
encapsulation dot1Q 20 second-dot1q 200
ip address x.x.x.x 255.255.255.252
service-policy output xxx
interface GigabitEthernet0/0/0.1
description WAN_Backup
bandwidth 20000
encapsulation dot1Q 31 second-dot1q 310
Any help or tips in the right direction is greatly appreciated.
thank you
One Inside two Outside
what you need
static route with
one high AD <<- this for backup
other with IP SLA track <<-  this for primary
router will check the primary when it down (IP SLA is down) the static route will remove and backup static route will be now the primary for traffic
for NAT you need to use  PBR to match the interface
https://blog.router-switch.com/2013/08/steps-to-configure-static-nat-with-route-maps/
6 Replies 6
two port in same router and you want to use HSRP ??
That is the only redundancy protocol we use. this was just dropped on me to be fair with little to no explanation I kinda have to figure it out.
what you need
static route with
Thank you for taking the time.
For routing I have BGP running and can not switch.
neighbor x.x.x.x activate
neighbor x.x.x.x  send-community
neighbor x.x.x.x weight 2000
neighbor x.x.x.x  soft-reconfiguration inbound
neighbor y.y.y.y  activate
neighbor y.y.y.y send-community
neighbor y.y.y.y weight 1000
X-Primary Y- Backup
but you use weight so you config primary and backup by change wieght of prefix from both Peer.
can I see
show ip bgp ??
Thank you @MHM I just figured it out.
