100% CPU Utilization
Mero Cisco
Please look below:
    802  111112 12291699911391233 2 111  11 1 238
    803970803325311051499886984368672007601789007
100  *                 **   *
90 **             *  ***   *                   *
80 **             *  ***   *                   *
70 **             *  ***   *                   *
60 **             * ****   *                   *
50 **             * ****   *                   *
40 **             * *##*  **   *               *
30 **             * *###  **  ** *            **
20 ***   *   *  *****###******** *         * ***
10 ##***************#########*****************##
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
what may be the reasons that such kind of report I am getting ? The cpu utilization is 100%, don't understand why ? The situation is quiet ok now. The utilization is only 10-15% now, but few hours ago it was 100% and I am so worried that I may got same kind of situation in the future. I have connected different ISP's link in this router. But, only one ISP's link was affected. Would it be the routing problem, if yes it should have disturbed others also. But no disturance in other's link. Please help ?
what is the meaning of the following:
Yours,
Mero Cisco
This is CPU usage points. 88%, 00%, 23% etc. if I can read your pseudo-graphics right, but generally it is CPU usage.
___
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer"
Eugene Khabarov
Level 7
Level 7
show processes cpu sorted is always good point to start
also did you looked at this document:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
- Mero
___
