10GE port adapter in ASR 1001 chassis
szilard.matyas1
Dear All,
Will SPA-1X10GE-L-V2 work in ASR 1001 chassis with the integrated ESP and SIP?
Thx,
Szilard
adawa
Level 3
Level 3
Hello, szilard.
The SPA-1X10GE-L-V2 should work with an ASR 1001 as long as you have Cisco IOS XE Release 3.8.0S or higher. Is this for your existing ASR 1001, by the way?
Let me know if you have additional concerns or e-mail (adawa@cisco.com) me directly. Kind regards.
adawa
Level 3
Level 3
Hello, szilard.
Hi adawa,
Yes, existing. It just wasn't clear whether it works with the integrated 5G ESP.
Thx,
Szilard
You are most welcome, szilard.matayas1. Thanks for the rating as well.
Are you already working with a Cisco partner/rep for this requirement as well? Let me know if you need assistance on that department as I can check on SPA-1X10GE-L-V2 availability as well. Do send me an e-mail (adawa@cisco.com). Kind regards.
