1111 Won't pull DHCP for WAN from Comcast - Migration from 891
frayedends
Well I'm stumped for the moment.   I'm migrating my office from an 891 that just can't keep up with the speeds anymore to a new 1111-8P, and I can't get it to receive a DHCP address from Comcast via the same little Arris SB8200 I was using before.
I'm almost duplicating the config from the old to the new, although there's a few differences.   First, I was using reflexive access lists to do some firewalling on the 891.  That worked good, but the 1111 supports zone based, which I intend to use, but have not yet configured.
The config is attached, and I can do things internally, but there's no DHCP address assignment like I had working on the 891.   I do plan on using the 2nd Gig WAN interface to connect to the 2nd port on the SB8200 later, but I need to get this workin first.
I have tried the "renew dhcp gigabitethernet0/0/0" command to try to refresh it, but nothing happens.
Yes, the SB8200 is in bridge mode, the 891 gets a DHCP address just fine.
Any hints or direct help would be greatly appreciated at this point!!
chances are that the Arris/Comcast has stored the MAC address of your old 891 and tied that to their DHCP. Check the 'Addresses' in the Web GUI SB8200 Web Manager Screen Options (Table 4, page 18 of the attached manual):
https://www.midco.com/contentassets/a8faa9563b6b49e5b244ef7418c1b314/arris-sb8200-user-guide.pdf
In any case, make the configuration changes/additions marked in bold:
Gateway#sh run
Building configuration...
Current configuration : 7141 bytes
! Last configuration change at 20:19:14 GMT Tue Sep 7 2021
version 17.3
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname Gateway
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT -6 0
ip name-server 8.8.8.8, 8.8.4.4
no ip domain lookup
ip domain name local
login on-success log
subscriber templating
no device-tracking logging theft
license feature hseck9
license udi pid C1111-8P sn [xxx]
license boot level securityk9
license smart reservation
memory free low-watermark processor 71820
diagnostic bootup level minimal
username [xxx] privilege 15 secret 9 [xxx]
redundancy
mode none
vlan internal allocation policy ascending
no lldp tlv-select management-address
no lldp tlv-select port-description
no lldp tlv-select system-capabilities
no lldp tlv-select system-description
no lldp tlv-select system-name
no lldp tlv-select port-vlan
no lldp tlv-select mac-phy-cfg
no lldp tlv-select power-management
no lldp tlv-select 4-wire-power-management
interface GigabitEthernet0/0/0
description WAN to Comcast
ip address dhcp
ip nat outside
--> no ip access-group 197 in
--> no ip access-group 197 out
negotiation auto
no ip virtual-reassembly
interface GigabitEthernet0/0/1
ip address dhcp
shutdown
negotiation auto
interface GigabitEthernet0/1/0
spanning-tree portfast
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
description Internal VLAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
no ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
--> access-list 1 permit 10.10.10.0 0.0.0.255
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
22 Replies 22
Gateway#sh run
version 17.3
service call-home
hostname Gateway
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
redundancy
mode none
ip address dhcp
ip nat outside
negotiation auto
ip address dhcp
shutdown
negotiation auto
interface Vlan1
ip nat inside
no ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
frayedends
Greatly appreciate the help with that!!  I am wondering if you can elaborate on why using that "permit ip any any" ACL doesn't work in that situation?
with NAT, an ip any any access list does not work, as far as I recall it is because with that access list, there is no source, so NAT does not support it.
Hello
Using the any any  in a nat acl can produce non deterministic results regarding your routing and NAT
it can nat packets you don’t wish to nat so best practice is to specify the network you wish to Translate leaving “other” packets to egress the wan interface untranslated .
Kind Regards
Paul
Thanks for the clarification!   Now I need to read 234,523 pages on zone-based policies to understand how to do the firewall.
instead of reading all these pages, you can leave it to us ! I'll put together a basic, standard Zone Based Firewall for your configuration and send it over...
That'd be great!   I do still want to understand the how and why, but I'd be gracious for any help!
3 zones, internet (wan), intranet (internal 10.10.10.0 255.255.255.0), and a single server in a dmz.   The dmz server is rdp access from in or out (there is a static route for it on 3389).
here is the Zone Based Firewall configuration (ZBF related lines marked in bold
Gateway#sh run
version 17.3
service call-home
hostname Gateway
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
zone security INSIDE
zone security OUTSIDE
redundancy
mode none
ip address dhcp
ip nat outside
zone-member security OUTSIDE
negotiation auto
ip address dhcp
shutdown
negotiation auto
interface Vlan1
ip nat inside
zone-member security INSIDE
no ip http server
access-list extended 111
10 permit udp any any eq 67
access-list extended 112
10 permit udp any any eq 68
ip access-list extended OUTSIDE-TO-INSIDE-ACL
permit icmp any 10.10.10.0 0.0.0.255
class-map type inspect match-all INSIDE-TO-OUTSIDE-CM
match protocol https
match protocol dns
match protocol udp
match protocol tcp
match protocol pop3
match protocol smtp
match protocol icmp
class-map type inspect match-all OUTSIDE-TO-INSIDE-CM
match access-group name OUTSIDE-TO-INSIDE-ACL
class-map type inspect match-any SELF-TO-OUTSIDE-CM
match access-group 111
class-map type inspect match-any OUTSIDE-TO-SELF-CM
match access-group 112
policy-map type inspect INSIDE-TO-OUTSIDE-PM
class type inspect INSIDE-TO-OUTSIDE-CM
inspect
class class-default
drop log
policy-map type inspect OUTSIDE-TO-INSIDE-PM
class type inspect OUTSIDE-TO-INSIDE-CM
pass
class class-default
drop log
policy-map type inspect OUTSIDE-TO-SELF-PM
class type inspect out-OUTSIDE-TO-SELF-CM
pass
class class-default
drop
policy-map type inspect SELF-TO-OUTSIDE-PM
class type inspect SELF-TO-OUTSIDE-CM
pass
class class-default
drop
zone-pair security IN-TO-OUT-ZP source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-TO-OUTSIDE-PM
zone-pair security OUT-TO-IN-ZP source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-TO-INSIDE-PM
zone-pair security OUTSIDE-TO-SELF-ZP source OUTSIDE destination self
service-policy type inspect OUTSIDE-TO-SELF-PM
zone-pair security SELF-TO-OUTSIDE-ZP source self destination OUTSIDE
service-policy type inspect SELF-TO-OUTSIDE-PM
control-plane
line con 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
Thanks for all of that!   I had done a little work on it, but was starting to run into some issue.   I did notice one thing in yours, this section here:
match protocol dns
match protocol udp
match protocol tcp
match protocol pop3
match protocol smtp
match protocol icmp
I believe that should be "match-any"?   As match-all it doesn't work and blocks everything.  If that's not correct, please advise, as I missed something else!
Making that change enabled it to work, and I went on to add in the DHCP addresses, and the other VLAN for the DMZ server, and I used your examples to configure the ZBF for that as well.   As of now, I believe everything is working.  Can you look over the final config and see if you see any issues or potential problems?   Attached with the crypto stuff cut out.
The DMZ server needs to be accessed via RDP on 3389 from inside, or outside the network.   It also needs to be able to send email only - no receive, and get windows updates via https, and should not respond to icmp.   There are no other connections to/from that server.
you are absolutely right about the match any.
I'll check the config and get back with you...
the config looks perfect !
George, having a little problem with this though.   All our internal clients on VLAN1 were getting DHCP addresses via the Comcast WAN, and not from the router.   If I get rid of the two ACL's and maps you had in yours to allow those requests in and out (self-out, out-self), then the WAN can't get it's address.   So I made a few changes, it seems to work from the client side.  They are getting internal addresses now, and so is the WAN if I reload.
Also the VLAN2 wasn't able to access any internet, so I added in DNS and HTTPS so it's windows update can work.  That seems fine now too.
Can you take a double-check to see that I didn't miss anything?   There's a situation every so often where the console locks up.   Such as:  sh dhcp lease *, it goes black and I can't input or break.  Log entries are still listing on the console page, but no more input.   Haven't figured out why this is happening yet.
the config looks fine. When you say the console locks up, from where are you accessing the console ?
Via the console cable to USB.  Works fine, except on a few commands which it locks up.
Actually, the config isn't working 100%, I've still got some devices getting IP addresses from outside.
