1721 ADSL Set-up...Another Try
anthonym
I am trying to set up a 1721 router with an ADSL line in the uk. I have the details from the ISP as:
VPI: 0
VCI: 38
Protocol: PPPoA
Modulation type: vcmux
Auth Type: CHAP
IP Range: 80.x.x.185/29
I have looked at the ADSL example configs at http://www.cisco.com/en/US/tech/tk175/tk15/tech_configuration_examples_list.html. There is no config that contains both CHAP, and a range of public, static IPs.
Attached is a config I have cobbled together. Is this likely to work? What changes would you suggest.
I would like to have the router at the adrdress 80.x.x.185 and servers/firewall at the 80.x.x.186, 187, 188, 189, address.
All help greatly appreciated!
Anthony
anthonym
The config I outlined does in fact work. Once I typed the static IP address in correctly!
Thanks to cisco for putting the more detailed config docs up on the 24th. They halped me no end.
