08-29-2006 11:17 PM - edited 03-03-2019 01:49 PM
I had next configuration of 2811 router-
interface Serial0/1/0
description ###Port to MPLS 384 kbps ###
encapsulation frame-relay
load-interval 30
frame-relay interface-dlci 16
frame-relay lmi-type ansi
service-policy output VoIP
policy-map VoIP
class VOICE
set ip precedence 5
priority 256
class SIGNAL
bandwidth 8
set precedence 3
class-map match-all SIGNAL
match access-group name signaling
class-map match-any VOICE
match protocol rtp
match access-group 101
That policy worked without problems.
I tryed to configure FRTS and set the fragment size -
map-class frame-relay VOIPovFR
no frame-relay adaptive-shaping foresight
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
frame-relay fragment 480
load-interval 30
frame-relay traffic-shaping
class VOIPovFR
After applying that my router became unaccessible, the cpu load growed up to 40% and the packets which floated through that interface also was upper 480 bytes. Seems it was not worked.
Where i was wrong?
08-30-2006 11:06 AM
Your config looks great. The only thing I can think the problem could be is that you didn't enable fragmentation on the other end.
When you do this, all packets over 480 bytes are fragmented by frame relay, and will be dropped since the other end doesn't recognize the fragmentation header.
Will
08-30-2006 09:49 PM
yes, i didn't do it... but at the other side i have SP router-it's MPLS port. How to be in that situation?
08-31-2006 10:02 AM
You're going to need to call your telco and ask them to fragment to the same value you are.
Most of the time they'll be happy to do it.
08-30-2006 08:00 PM
i think you should do fr framgment on both sides.
